Pre 84 Trucks 1st gen pickups
CHG Light?
Old Jun 19, 2010 | 03:06 PM
linkspast's Avatar
CHG Light?
im the owner of a 77 pickup
20r
and the CHG light came on.
I have put in a newer battery and switched the alt, the light is still on do I need to reset something, or is my batery just not charged?
Old Jun 19, 2010 | 03:11 PM
1981 yota's Avatar
my 81 with a 22r has the same problem. it might just be a loose wire like mine
Old Jun 20, 2010 | 06:51 AM
swampfox's Avatar
check the batt voltage then start the truck and check it again .there should be an increase. you will need a good volt/ohm meter. if there is not a change it might be the voltage regulator or bad connection. also check the fuses.
Old Jun 20, 2010 | 08:26 AM
rowdy235's Avatar
Hit the PS side dash. If it goes off your charge light relay is bad. Thats what happened to my 82, but toyota wanted like 80 bucks for the relay. I just unplugged it
Old Jun 20, 2010 | 09:47 AM
1981 yota's Avatar
or find a aftermarket gauge pod with a volt meter thats what i did
Old Jun 21, 2010 | 11:52 AM
linkspast's Avatar
Which fuses should I be looking at? the ones in the dash, or are there other ones?
also where is the voltage reg?
My truck is still dying just in the middle of the road.. kind of sucks..
any other advice?
Old Jun 21, 2010 | 12:14 PM
Tofer's Avatar
Sponsor
check the fuses.. i had an 81 that the charge light would come on until i ran the RPMs up to about 5k.. then it would go off. i found that there is a fuse labeled ENG that had blown..
Old Jun 24, 2010 | 01:08 PM
linkspast's Avatar
Where is the voltage regulator?
and how can I tell if its not functioning properly?
Old Jun 24, 2010 | 01:41 PM
Tofer's Avatar
Sponsor
Voltage regulator is on the driver fenderwell under the hood.
Old Jun 24, 2010 | 02:14 PM
linkspast's Avatar
Uploaded with ImageShack.us
I put a milti meter on the two contact's and got less than one volt.. is that right?
Old Jun 24, 2010 | 11:18 PM
wentz912's Avatar
Get a chiltons or haynes manual, they both have the testing procedure.
Old Jun 25, 2010 | 07:49 AM
swampfox's Avatar
autozone has free online manuals .you will have to register and do a little searching ,they like to push the pay site but the free site is there. also most local libraries has free online data bases, you just have to get a library card.
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
