Pre 84 Trucks 1st gen pickups
80 4x4 wont move
Old Oct 10, 2007 | 11:00 PM
celicaflyinglow's Avatar
80 4x4 wont move
my 22r runs but as soon as u put a load on it like trying to go somewhere it dies any ideas please help
Old Oct 10, 2007 | 11:06 PM
Jeenyus04's Avatar
i'd check your timing.
Old Oct 10, 2007 | 11:36 PM
stormin94's Avatar
I dunno, check your fuel filter, plugs, and check and make sure the gas in your tank isn't old.
Old Oct 11, 2007 | 02:33 PM
rowdy235's Avatar
had the same problem with my 77, put it into drive and it'd die. Timing was way off.
Old Oct 11, 2007 | 02:37 PM
Firefightertaco's Avatar
let it warm up first and see if that helps, how long has it been sitting? the carb. maybe messed up
Old Oct 11, 2007 | 02:52 PM
denro's Avatar
the fuel filter needs changing i bet...its cheap enough, try that first. good luck, keep us posted what the problem was.
Old Oct 11, 2007 | 02:59 PM
4banginRunner's Avatar
like everyone else..check your fuel filter first, my 79 did the same
Old Oct 16, 2007 | 09:46 PM
the_supernerd's Avatar
It could also be the carburetor. Will it rev past idle? There is a seprate circuit in the carburetor for idle. If the main circuit is clogged, then it would idle well, but not rev.
raptor510
Feb 17, 2017 07:11 AM
coryc85
Sep 9, 2015 06:24 AM
skebe22RTE
Jul 31, 2015 02:03 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
smiley52
Jul 11, 2015 05:16 AM
