Pre 84 Trucks 1st gen pickups
1982 Toyota: Valve Cover Gasket Replacement
Old Sep 12, 2007 | 05:26 PM
rowdy235's Avatar
I have decided to do a semi-write up of this event.
Okay, here is the engine to start with
I began by removing the air cleaner unit,
Next, I removed all of the devices/hoses mounted to the cover
Then I unbolted it, if it doesn't come loose, remove the washers on the bolts, mine then lifted right off. I then removed the cover to my tailgate workbench.
Then I took off the plastic cover on the inside of the top, and "dug out" the ORIGINAL (300k miles) grommet. New Grommet & Valve and it was as good as new. Then I routed the new gasket into the channel, and placed it back on the engine after replacing the "half moon" pieces in the front and back.
I then tightened the bolts down. The manual says 9 ft lbs, I didn't have a torque wrench, so I just went about two turns past finger tight. After that, I replaced everything. It idled better, and drastically reduced my oil leak.
These are the old parts (minus the washers)
Old Sep 12, 2007 | 08:51 PM
dropzone's Avatar
Fossilized
Truck looks pretty good for 300K on it! How did the rockers etc look under there?
Lots of good wheeling down by Sweet Home, though I heard they have closed some of the access to the Bohemian Mines area though...
Old Sep 13, 2007 | 05:13 PM
rowdy235's Avatar
Thanks, I think it looks descent. The engine was rebuilt around 50k ago, so the internal components looked good. I can't for the life of me figure out why they did not replace the pcv/grommet when they rebuilt it? Oh well, its done now. Yea they did close the trails. Sucks, but what can ya do?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
