Pre 84 Trucks 1st gen pickups
Sway-Bar
Old Dec 30, 2007 | 08:04 PM
camo31_10.50's Avatar
Sway-Bar
what and where is the swaybar on my 1980 4x4 p/u ...i see a bar under the front...but idk what it is..could someone show me a pic...i would like to disconnect it..because i heard it lets the axle flex better...if so..i want to remove it..because my stock suspension doesnt hardly flex ANY in the front...how will it perform on the road..is there one in the rear...if so..pics and info on it to please..lol thanks alot!!
Ken,
Old Dec 30, 2007 | 09:09 PM
81redbluffyota's Avatar
From: I live in Red Bluff ca. Right by the Sacramento river
Its the bar right next to the dipstick for the exhaust manifold.
No seriously, It is shaped like a long u?.?. It is connected to the frame and your axle, should have bushings. Its really right in your face if you stick your head under the truck. I have mine removed. It does let it flex better, but it also leans a lot more in the front when you take turns. And no your rear doesnt have one. Some axles have a rear sway bar, but usually later models.
Old Dec 31, 2007 | 07:29 AM
Island_Yota's Avatar
Thats the absolute first thing that came off my truck, its basically a 3/4" round bar that snakes along the front axle and is attached with some long bolts and bushings, cant miss it.
This is off an IFS truck but it should give you an idea of what it looks like:
I have about 4 of them laying around, one even has brand new poly bushings but my trucks never gonna see a sway bar, or the torque arm ever again.
Old Dec 31, 2007 | 07:49 AM
4Crawler's Avatar
Front sway connects to both sides of the axle and bolts to the frame:
http://www.4crawler.com/4x4/CheapTricks/SwayBar.shtml
Passenger side end link:
No rear sway bar.
Old Dec 31, 2007 | 09:34 AM
4banginRunner's Avatar
the long box is the sway bar, the vertical boxes are the links, if ur looking to disconnect just unbolt them
more likely than not, the bolts will snap, strip out, and or bend, so if u plan to put it back on, pick up a new set at auto zone/ advanced auto they r cheap, around 15-20 bucks\
there is none in the rear, and street performance wont be noticeably affected unless u hit the highway or really hard turns at speed, the body will just "roll" more
Old Dec 31, 2007 | 10:28 AM
bigarms23's Avatar
unbolt it and run the truck without one
Old Apr 24, 2014 | 06:02 PM
CAdot's Avatar
Erich_870
51
Dec 18, 2012 04:25 PM
puulboy
FJ Cruiser (Build-Up Section)
Mar 6, 2011 11:20 AM
RandyÄ
Oct 9, 2007 04:40 PM
Firefyter-Emt
Apr 22, 2003 07:54 AM
bbeast
28
Feb 9, 2003 05:27 PM
