Pre 84 Trucks 1st gen pickups
Place your bets.[no oil pressure]
Old Nov 2, 2007 | 08:48 AM
1eye's Avatar
Was driving the Toy the other day, shut it off, ran a errand, fired it back up and WTF. The Oil light stayed on and the gauge reads 0 oil psi. Got it towed back to my shop and put a "master gauge" on it last night, no pressure. Will have to dig into it this weekend, and with the club run to the sand-dunes coming up in 2 weeks, I hope I can get it fix in time.
SO, place your bets on what you think I'll find is the problem [sheared oil pump key, relief valve, pick-up tube fell off, etc]
Old Nov 2, 2007 | 09:13 AM
ydopen's Avatar
does it sound bad? One time my buddies did that and the wire by the oil filter was disconnected. Good luck.
Old Nov 2, 2007 | 02:07 PM
1eye's Avatar
Nope, sounded fine when i fired it up, was about to put it in gear when i did the "why is that red light on", followed by *&^% as i looked at the oil pressure gauge and shut it off. Run time 4 or 5 seconds tops.
Old Nov 2, 2007 | 02:50 PM
nix4x4's Avatar
Oil sender
Old Nov 2, 2007 | 04:02 PM
slacker's Avatar
so it started to "rattle" / "knock" ?
hard to believe the woodruf key would break , and a pluged/siezed pressure spring is only for over pressure .. pick-up tube - so rare , I have NEVER heard of it .
Old Nov 2, 2007 | 04:07 PM
SEAIRESCUE's Avatar
Gage problem......guess not.
Old Nov 2, 2007 | 05:44 PM
rowdy235's Avatar
when you mention "Got it towed back to my shop and put a "master gauge" on it last night, no pressure", that means you plugged another gauge into the plug where the sender was, correct? If thats so I am going to bet on some sort of malfunction in the oil passages or woodruff key as the drop happened so fast. If that wasn't another gauge its gotta be the sender IMO
Old Nov 2, 2007 | 06:38 PM
DeathCougar's Avatar
Define master gauge? Like you removed the sender and put a hand held oil pressure tester gauge on it?
Old Nov 2, 2007 | 07:12 PM
1eye's Avatar
A aftermarket gauge set{from MAC Tools} that I bought a few year ago when i worked at a "stealership" as a automotive tech. Gauge is[was] calibrated and I used it for testing tranny & engine oil pressures. Yes, pulled the sender out for the factory gauge, tapped in, POOP{can i say that on here } no pressure and no oil when i crank it over. NOT good.
Started taking pieces off tonight, we'll see how far I get, have to work all day Sat
[GREAT, now their talking snow for here, sigh, well that'll be "fun" too.]
Old Nov 2, 2007 | 09:07 PM
If you have sludge issues, you'll know it. But I have never seen a 22R sludged up, ever. And its not likely to be the pick up tube either.
I'd put my money on the oil pump. Good catch!
Old Nov 2, 2007 | 09:10 PM
superjoe83's Avatar
Ive seen the relief valve get stuck open before by a small piece of metal, before you tear into it too much take off the big nut on top of the oil pump and pull out the relief valve and inspect/clean i bet thats it, unless you did suck up a big chunk of something and jammed the pump=sheared keyway, good luck
Old Nov 8, 2007 | 07:44 PM
1eye's Avatar
Well, oil pump failure.
I'll have to do some more checking this weekend to see if its the main cause or just a symptom of some other problem.
Old Nov 8, 2007 | 08:38 PM
YAY I win. What do I win?
Old Nov 8, 2007 | 08:48 PM
jason191918's Avatar
instead of starting a new thread i will just ask it here. what is the pressure that the pressure relief valve is set at?
J
Old Nov 9, 2007 | 12:53 PM
surf4runner's Avatar
i was gonna say you got an oil change at jiffy lube and they forgot to put the drain plug in tight...
Old Nov 9, 2007 | 03:31 PM
slacker's Avatar
wow .. never seen a oil pump fail , with regular maintance thet is .
Old Nov 10, 2007 | 09:34 AM
rowdy235's Avatar
Any updates? Got 'er back together yet? Good Luck.
Old Nov 10, 2007 | 12:22 PM
1eye's Avatar
Putting it back together. Had to rig up a adapter so i could "pull" vacuum on the oil pick up to check it for leaks. It tested good, so I'm leaning towards the POS oil filter that came with the truck that allowed the oil to drain back[guess what brand im never using again, see oil filter thread elsewhere in the forum]
So I've put the new oil pump on and crank pulley. Thats as far as i got the other night. While its apart, I'm installing a new high output Alt up high on the right side of the engine[hope to keep it somewhat dryer on those deep water crossings] Will have to custom make mounting brackets for it and then put a new rad in while I'm at it.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
