Pre 84 Trucks 1st gen pickups
22re swap from celica into '80 toy truck
Old 12-30-2007, 09:25 PM
allcalwheelin's Avatar
so i picked up a 83 celica GTS. 22re. has anyone put one of these motors in a carbed truck? im wondering about the wiring and i know i have to change out the oil pan and pickup.
any info would be great, my crawler is sputtering out and now i have the solution!
feel free to call me if you would rather talk then type 707 703 2924 Don
Old 12-31-2007, 10:56 AM
rowdy235's Avatar
Look up a 22re swap. Wiring-wise it should be the same to adding FI. I think you'll end up needing 6 wires, or something like that. Because its coming from a celica, I'd probably just run new wires, as opposed to keeping the celicas harness. Just less wires to worry with.
Hope this helps.
Old 12-31-2007, 01:10 PM
Belize Off Road Team's Avatar
you should ask how much this guy wants for his V8:
http://jalopnik.com/339171/the-v8+po...ns-frostys-ass
or how about this V12:
http://jalopnik.com/339153/beautiful...8-hp-per-liter
Old 12-31-2007, 05:44 PM
84sr5yoty's Avatar
The motor will bolt directly in with the expectation of the oil pan and pickup, as you already know. The only time consuming part will be removing the entire harness from the Celica and implementing it into the truck.
If you have the time and the $$$, do it right and rebuild the engine and have the fuel injectors (including the cold start injector) ultra sonically cleaned. Installing a new clutch and front seal on the trans would be wise.
matrad
01-04-2019 03:06 PM
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
puffin04
07-10-2015 09:17 PM
noahstancik
07-10-2015 11:18 AM
93handmedown
06-19-2015 06:26 PM
Quick Reply: 22re swap from celica into '80 toy truck
