Pre 84 Trucks 1st gen pickups
Brake and Batt. light won't turn off.
Old Jan 31, 2008 | 03:39 AM
Ktm526's Avatar
I'm a newbie here so if this has been discussed before please forgive me. I've got an 82 4wd pickup with around 300,000 miles on it. The truck runs great but when I start it the brake and battery light stay on.Sometimes they will go off if I hit a bump but will eventually come back on. Any ideas where should look first? Thanks.
Old Jan 31, 2008 | 04:37 AM
toytech76's Avatar
Your alternator isnt charging. More than likely the brushes are bad and worn out. I sell sets of brushes for $15 shipped to you. Better to fix your alternator than to go buy a rebuilt kragen piece of junk. Toyota reman's are expensive. Let me know if you are interested
Old Jan 31, 2008 | 02:43 PM
Ktm526's Avatar
I checked that it is charging. But thank you for the reply. I appreciate any help.
Old Jan 31, 2008 | 02:46 PM
landshrk's Avatar
I'm having the same problem in my '87 2WD, but only at idle. If I give the throttle a little blip, they disappear for a moment, but as soon as it's back down to idle, there they are again, faintly glimmering and taunting me in the face. I went to vatozone and picked up a new set of brushes for like 4 bucks, and I'm waiting for it to quit raining to go replace them (no garage...).
Lemme know if it works for ya, 'cause from what I hear, most alt. problems can be fixed with new brushes, esp. when they've a coupla hundred thou on them. Otherwise, just get a reman alt (about $80), and toss the old one.
*EDIT* BTW, anyone know of a good step-by-step for an alt rebuild? Never worked on a vehicle this old, much less my 22R. I'd kinda like to not eff it up too bad... Did just buy the dman thing...
Old Jan 31, 2008 | 05:51 PM
rowdy235's Avatar
I have had this problem before. With the lights on and the engine idling, look up under the passenger side dash. Along the wall there should be a relay mounted with a green connector going to it. This is the charge light relay. Tap it a few times and see if the lights turn off, if they do the relay is your problem. On mine hitting the PS dash would turn them off.
Toyota will charge ~$80 for one, I got mine from another member on here. Or you could just take it off and leave it off, I did that, and the only bad thing is the light never comes on.
Old Feb 1, 2008 | 10:44 AM
Ktm526's Avatar
Hey Rowdy235 thanks a million that was it! Those lights were driving me crazy. What a great website this is.
Old Feb 1, 2008 | 02:37 PM
rowdy235's Avatar
You're welcome. I know first-hand how dang frustrating that problem is.
Old Feb 20, 2008 | 09:30 AM
fredbauer's Avatar
Rowdy, You are the man. I've been fighting with the alternator light since last July and you are the first to come up with the solution. In the process I rebuilt the alternator and bought a new ICU. You deserve suggestion of the year award. Now all I have to do is find a replacement for the relay. Thanks again. Fred.
Old Mar 4, 2008 | 11:55 AM
millertime1367's Avatar
Does the charge light relay have anything to do with the charging? My truck is still overcharging, can't find the problem, and havn't found a wiring diagram that is easily interpreted.
Old Mar 4, 2008 | 04:43 PM
rowdy235's Avatar
No, the relay just controls the light
Old Mar 4, 2008 | 11:45 PM
Sked's Avatar
Check the IC regulator on top of the Driver side wheelwell. Ive had this problem too many times. Battery used to boil over, then i replaced it with an new Toyota IC regulator and its good. Ive had problems with 'other' brand names twice, then i got and used toyota one from a Bud.
Make sure all those old connections are still good with good battery contacts and good grounds on both the Alt and IC regulator.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
raiderhawks00
Jul 8, 2015 06:23 PM
