Pre 84 Trucks 1st gen pickups
doing the 63 chevy spring swap, had one question
Old Nov 14, 2007 | 08:00 PM
MikeKaduce's Avatar
i've searched on a few different sites, and pretty much have it figured out, except for one little detail that i'm foggy on. if anyones done this swap, can you tell me if i'm using a single 9 inch shackle setup and relocating my front hanger 11 inches forward from stock, does this necessitate shackle relocator plates and if so how far back from stock should these be mounted?
thank you
Old Nov 14, 2007 | 09:04 PM
SCYOTA's Avatar
What truck are we talking about here? I'm guessing that you have a 1st or 2nd gen because you stated that the front hanger will be moved 11" forward. If you are using a single shackle then I would relocate it back about 4". If you decide to go the double shackle route then you can use the factory shackle hanger. I would start by mounting the spring hangers and then seeing where it would be best to mount the shackle hanger. You will find that it is somewhere around 4". If you try to just use a 9" shackle the angle will be fairly severe and you will loose some of the lift height. Why not take the extra time and relocate it?
Old Nov 14, 2007 | 11:06 PM
MikeKaduce's Avatar
this will be done on my 1981 Trekker
i've heard horror stories about the double shackle setup! this will more or less be a daily driver
Old Nov 14, 2007 | 11:34 PM
dropzone's Avatar
Fossilized
you will probably find you answer in this FAQ from Pirate:
http://www.pirate4x4.com/forum/showt...threadid=20665
Flying91
45
Apr 11, 2024 04:39 PM
Coreyr384
Jul 10, 2015 11:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
wilbertd
Jul 6, 2015 07:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
