Pre 84 Trucks 1st gen pickups
4 speed to 5 speed conversion
Old Dec 23, 2007 | 09:35 AM
WesternClimax's Avatar
I have a 1981 4x4 with a 22r and a 4 speed. The transmission and transfer case are trashed, so I found a 5 speed and transfer case out of a 1893 4x4. Is this a bolt on swap?
Old Dec 23, 2007 | 09:53 AM
DeathCougar's Avatar
the 5 speed will be a bit longer, so if you get drivelines, shifters, and the mount, it will.
Old Dec 23, 2007 | 01:06 PM
4banginRunner's Avatar
dont think they made toyotas in 1893
but, liike deathcougar said, the 93's 5spd will be longer and the x-member will need to be relocated
Old Dec 23, 2007 | 01:42 PM
86toysr5's Avatar
maybe he meant 1983?
Old Dec 23, 2007 | 11:21 PM
Well if its a 1983, going into a 1981, im not 100% sure if its different.
I assumed he meant 1993, which of course will be longer.
Old Dec 24, 2007 | 12:13 AM
Typo. 1981 Truck, 1983 Tranny.
Old Dec 24, 2007 | 07:52 AM
83 tranny with bolt up and x-member will match
Old Dec 24, 2007 | 03:07 PM
yota81's Avatar
the crossmember will work with a 5 speed even though he is swapping out a 4 speed? i thought the crossmember had to be modified to fit the extra length of a 5 speed.
Old Dec 24, 2007 | 03:33 PM
I freakin' hope so. I better start calling around to find a 5speed crossmember asafp. Pisses me off that I have to do this in the first place, but its my fault I bought the sucker with a bad transmission.
Old Dec 24, 2007 | 05:09 PM
thats if the 5spd is out of a 84+ truck/4Runner
4/5 spd x-member location is the same on all 79-83 trucks
r3dfish
54
May 16, 2016 10:31 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
BeMiceElf
Oct 10, 2015 09:40 PM
129Creepin
Aug 5, 2015 10:12 PM
wilbertd
Jul 6, 2015 07:39 AM
