Pre 84 Trucks 1st gen pickups
'80 makes clicking sound in front end in 4wd
Old Nov 2, 2007 | 10:45 PM
mrtejman's Avatar
My '80 pickup makes a clicking sound in the front end when engaged in 4x4. I thought it was the angle so I put axle shims in but it still makes noise. Does anyone know what this could be?
Old Nov 2, 2007 | 11:07 PM
b.miller123's Avatar
CV boot? (just kidding, you don't have those)
somebody put a baseball card in your spokes (damn kids)
do birfields click? (never had a solid axle toyota)
is it dependant on just speed? or does turning make it worse?
you could pull the driveshaft, lock the hubs and drive around, if it stops making the noise then it's something with the driveshaft (i have no idea what that could be) if it still makes the noise then you know it's not the driveshaft angle
I'm not 100% that this would be an effective way a deducing your problem, and my logic may be incorrect so anyone feel free to chime in and correct me
Old Nov 2, 2007 | 11:17 PM
mrtejman's Avatar
Yeah I think I am going to pull the driveshaft sometime this weekend and see whats up
Old Nov 2, 2007 | 11:21 PM
hopefully that will point you in the right direction, like I said, I'm not %100 sure this will work, but it could tell you something
another thing you could do is get the front wheels off the ground lock the hubs and spin the wheels by hand see if you hear the noise that way
Old Nov 3, 2007 | 10:53 AM
Island_Yota's Avatar
Do you wheel it hard? What size tires? Could be a cracked birf.
Old Nov 3, 2007 | 03:20 PM
slacker's Avatar
I would think constant-velosity joint.... on the front drive shaft .
Old Nov 3, 2007 | 04:46 PM
mrtejman's Avatar
There is no CV its solid axle, it has 35's and it gets rallied
Old Nov 3, 2007 | 11:14 PM
i think he meant U-joint, but I've never heard of those "clicking"
Old Nov 4, 2007 | 09:14 AM
slacker's Avatar
No .. I ment the DRIVE shaft or Proppeler shaft as sometimes called ... just like I said .
If its a factory shaft , it has a constant velosity up by the transfer case . if not then I didnt know you changed it . something you didnt mention .
Old Nov 4, 2007 | 09:25 AM
KevinInSac's Avatar
Put it up on jack stands and let er idle. Get under there and listen for the noise. That'll tell you.
Old Nov 4, 2007 | 03:31 PM
slacker's Avatar
do a search .. you'll soon be edgimicated .
Old Nov 4, 2007 | 06:39 PM
4Crawler's Avatar
Could be a cracked birfield housing. Mine made a clicking noise when they failed. Also check the CV and u-joint on the front driveshaft. Should be no play ferlt in the joints.
Old Nov 5, 2007 | 04:20 AM
82yota's Avatar
I've had a clicking noise come from the CV on the front shaft on my 82. Took it apart and the pin in the CV was screwed so it had play. Alot of people dont grease the shafts correctly and this could be one of them.
Old Nov 7, 2007 | 04:08 PM
eightduceyota's Avatar
Mine did the same thing its more than likely the front drive shaft where the two u-joints are.
Old Nov 7, 2007 | 04:32 PM
slacker's Avatar
I wonder what happened ????
he hasnt posted again.
Old Nov 8, 2007 | 11:57 AM
mrtejman's Avatar
I have been too busy to mess with it yet, but thanks for all the info. I am going to check it out this weekend
truckmike26
Jul 24, 2024 10:24 AM
Daneums
Jun 29, 2015 06:38 AM
miceal383
Jun 29, 2015 12:27 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
XtremeOff-Road
Jun 23, 2002 11:17 AM
