Pre 84 Trucks 1st gen pickups
78 4 to 5 speed swap
Old Nov 7, 2007 | 11:44 PM
benyota's Avatar
I am in the process of swapping my 4speed for a 5 speed. The trans bolted up fine, but the crossmember doesn't line up with the bolt holes. both trannys are from a 78 longbed. any help would be appreciated.
Old Nov 8, 2007 | 07:30 AM
dropzone's Avatar
Fossilized
5 Speeds are about 4" or so longer. You will need to make some new brackets for your crossmembers...not much of a help I know but....
Old Nov 8, 2007 | 07:49 AM
SEAIRESCUE's Avatar
Where's the 78 5 speed X-member?
If not available, most folks use a 3/8" thick flat plate to extend the
X-member to the transmission mounting holes. Some weld it on and
some use bolts.
Hope this helps.
Old Nov 8, 2007 | 02:54 PM
rowdy235's Avatar
On my truck the PO installed a plate on the cross member to extend back and mount the tranny. Just 4 bolts on the X-member secures it.
Old Nov 9, 2007 | 06:02 AM
benyota's Avatar
some use bolts.
Hope this helps.
I have it, but i guess I still have to make something
Alex Bessinger
Aug 31, 2015 09:17 AM
deepmarsh
Aug 6, 2015 03:44 AM
kyletbert
Jul 17, 2015 11:39 AM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
