Transfer case output shaft seal and bearing? - YotaTech Forums
Pre 84 Trucks 1st gen pickups
LinkBack Thread Tools Search this Thread
Old 11-02-2007, 11:04 PM   #1
My yota is spilling a little gear oil. The front output shaft is leaking where the driveshaft mounts to the transfer case, and there is about 1/4 in of slop in the shaft going into the case when 4wd is not engaged (don't know if this is normal or not). I believe I am going to have to replace the output shaft bearing and seal, but don't know how big of a job I am getting myself into. Do you have to open the case to replace this bearing, or is this something you can do from the outside? The 4wd works, but I havn't tried it for long. I have been restoring this truck for the last 2 years, ran out of money for a while, now I'm finishing it. I havn't drove it for more than 2 miles the whole time I owned it. Its got the original 80 4spd tranny, and transfer case, if that matters. Thanks in advance!
joshd is offline   Reply With Quote
Old 11-03-2007, 12:59 AM   #2
superjoe83's Avatar
its been awhile since Ive had a gear drive case apart, but I'm pretty sure you have to take the back half of the case off to get the front drive out, you should be able to replace the seal with out splitting the case
superjoe83 is offline   Reply With Quote
Old 11-03-2007, 07:59 PM   #3
Fossilized
Staff
dropzone's Avatar
Here is a link to a Video on transfercases that Trail-Gear did. Don't think there is sound but thought that it might help you out:
http://www.trail-gear.com/videos/toy-tcase.wmv
Here is the link to the 4.7 gear install (know it is not what you are doing) but pictures help to show some of the work involved with transfer case...http://trail-gear.com/tech/470install/470inst.html
dropzone is offline   Reply With Quote
1977 Hilux Project PNWrider Newbie Tech Section 5 10-30-2015 08:14 AM
93 toyota pickup 4wd dash light stays on ViperTT 86-95 Trucks & 4Runners 8 08-14-2015 05:27 AM
Transfer case overfilled with oil or ATF yourrealdad 95.5-2004 Tacomas & 96-2002 4Runners 3 07-29-2015 11:08 AM
WTB[PacSoWest]: 23 spline with 4.7 gears SMOD Items Wanted 0 07-23-2015 10:29 PM
Write-up: Converting forward shift transfer case to a top shift for crawl box crashburnoveride 86-95 Trucks & 4Runners 1 07-10-2015 06:39 AM
Tags
bearing, case, change, front, output, play, rear, replace, replacing, seal, seals, shaft, toyota, transfer, transfercase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
