Pre 84 Trucks 1st gen pickups
Lockers VS Welded
Old Nov 8, 2007 | 02:49 PM
CRONK4X's Avatar
Lockers VS Welded
I need some help i have a 82 truck & don't have a whole lot of money so i was thinking of getting Detroit locker in the rear and welding the front.
Is that ok or is it a bad idea?
Old Nov 8, 2007 | 02:53 PM
rowdy235's Avatar
Thats how I would do it.
Old Nov 8, 2007 | 03:22 PM
AxleIke's Avatar
Do you wheel mostly in mud?
If so, that will likely be fine.
If you wheel on ANY high traction surface, rocks, even hard pack dirt, you'll need to get out and unlock one hub if you want to steer.
You'll be able to turn in mud and sand. Sort of.
Old Nov 8, 2007 | 04:03 PM
85toy's Avatar
i thought you could steer just fine on drit even but just not on pavement. am i wrong?
Old Nov 8, 2007 | 04:31 PM
d0ubledown's Avatar
weld em both. then get hydraulic ram assisted steering...
Old Nov 8, 2007 | 04:33 PM
AxleIke's Avatar
Thats the other way to do it.
Old Nov 9, 2007 | 11:20 AM
mrtejman's Avatar
I think you can break the birfields if you weld the front and drive on pavement, I was planning on welding the rear end and putting an aussie locker in front on my truck.
Old Nov 9, 2007 | 11:50 AM
AxleIke's Avatar
you can break them in the dirt too, they aren't that strong.
If you want cheap lockers, or welding, you will have drawbacks. There is no way to avoid that.
Look at it this way:
Cheap Lockers or Welding
Pros: Cheap, great traction off road.
Cons: Hard to steer, on road manners can really suck.
ARB/Elocker
Pros: Goes from fully open to fully spooled with the flick of a button, zero on road and offroad drawbacks.
Cons: Expensive
Everything has its cost. I'd look at what breaking axles and not being able to steer is going to cost you in terms of your time.
Old Nov 13, 2007 | 04:03 PM
redneckabbott's Avatar
I'd weld the rear and put locker up front so it can unlock when turning and won't be so much binding and stress on driveline. Seems more logical like that.
Old Nov 18, 2007 | 09:29 AM
monstertruckman's Avatar
i put an arb in the rear and a true trac up front
Old Nov 18, 2007 | 09:42 AM
dropzone's Avatar
Fossilized
Welding your diffs sure seems to be cheap route to go but people realize later that they are eating tires due to uneven wear.
If you weld the front, spend the money on a Twin stick so you will be able to turn....again that negates the Lincoln locker approach.
Personally I am doing Aussie lockers front and rear $240 per locker plus $200 for the Marlin Twin stick kit.....
Old Nov 18, 2007 | 12:04 PM
4banginRunner's Avatar
lock the rear either spool or welded, leave the front open until u have enough $$ for a selectable locker, locking the front will cause more problems than its worth
Old Nov 18, 2007 | 07:50 PM
AxleIke's Avatar
With a welded the twin stick trick doesn't work. It works with auto and lunchbox lockers because you disengage power to the front, and the locker unlocks. With welded, you still can't turn. You have to unlock a hub.
Old Nov 19, 2007 | 12:55 PM
dropzone's Avatar
Fossilized
Thanks for educating me again....I thought that it would free it up...appreciate you squaring me away...
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
