Pre 84 Trucks 1st gen pickups
driveshaft
Old Jan 7, 2008 | 09:41 PM
Island_Yota's Avatar
driveshaft
I want to lift the front of my truck about 1.5" taller, plan on dropping the hanger a bit and some slightly longer shackles so the truck sits level. Problem is my front driveshaft is at its limit slip and u-joint angle wise, Im wondering what I can do(cheap) to fix this? The shaft has a double cardan joint, im wondering if I can eliminate that and run it a square shaft strait to the tcase flange to slacken the angle a bit ( I dont even think that makes sence?). And even more important, what pinion angle should I be running? might be easier just to fix that (doubt it).
Old Jan 8, 2008 | 03:00 AM
4banginRunner's Avatar
a front shaft off an IFS truck is a good bit longer than the 79-85 SA's
the IFS shaft will work up to about 4"'s of lift
it will also require drilling new holes on the flanges
Old Jan 8, 2008 | 01:00 PM
My stock one is o.k. at 4" of lift, doesn't bind up but with the extra 1.5" it wont be good.
Old Jan 14, 2008 | 10:17 AM
Datsunon40s's Avatar
i am running 6" of lift and an IFS driveline and ive never had a problem. Oh and about drilling the flanges you can pull apart the dual cardan joint and swap the flange from your old driveshaft
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
ToyotaMD
Aug 17, 2018 10:16 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
