Pre 84 Trucks 1st gen pickups
Water Temp Question
Old Mar 28, 2013 | 04:23 PM
83Toyota88's Avatar
Water Temp Question
Worked on my truck the other day and when I was done I forgot to put the clamp back the on top radiator hose and I went driving around and when I parked and got out I smelled a "hot" smell and saw antifreeze leaking under the truck. I realized what I did and put the clamp back on and put some antifreeze in it and went back home. Ever since my water temp never gets to the middle of the gauge like it used to, now it just goes about a 1/4 to a 1/3 of the way there. Any ideas?
Old Mar 28, 2013 | 05:12 PM
rworegon's Avatar
Likely air was sucked into the cooling system. Try burping the radiator.
Old Mar 29, 2013 | 07:07 PM
83Toyota88's Avatar
Burping it with the truck running?
Old Mar 29, 2013 | 07:24 PM
Co_94_PU's Avatar
Yep. If you can park with the nose on top of a slope even better.
Old Mar 30, 2013 | 06:15 AM
kawazx636's Avatar
Definitely air in the cooling system. Just run it from cold with the rad cap off and let it "burp" the air out. As the air comes out, put more fluid in. Once it heats up all the way, shut it down, let it completely cool, top off the fluid and you'll be good to go.
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
Jonny246
Jul 12, 2015 04:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
