Pre 84 Trucks 1st gen pickups
starting issues, real bad.
Old Mar 3, 2013 | 05:56 PM
mudbog01's Avatar
Okay, when truck is cold normally takes a minute or two to start.but after the truck is warmed up an all I drive about half hour shut the truck off not even for 5 minutes and it doesn't want to start again. And when it does start EVENTUALLY IT DOESN'T WANNA STAY RUNNING!! Idk what is going on I've been batteling this issue for the past month. Any suggestions?
Old Mar 3, 2013 | 08:34 PM
Baca17's Avatar
I would try the basics like fuel filter, spark plugs, wires, and cap.
Old Mar 4, 2013 | 10:38 AM
mudbog01's Avatar
New wires and plugs.. cap seems fine got it about a month ago. Where would I find the fuel filter? And note the carb is running very rich. If that means anything.
Old Mar 5, 2013 | 12:01 PM
mudbog01's Avatar
Still nothing! its only in the mornings now wehn the truck is cold that it doesnt want to start at all. it will crank and crank and crank but no fire and eventually i need to spray fluid in it just to get it going and after that ive gotten it to fire. and itll be fine for the rest of the day. its my daily driver and at the moment its not so reliable.. please someone guide me in the right direction!!
Old Mar 5, 2013 | 12:11 PM
thedrewski86's Avatar
I know what you mean man, my daily driver 22RE is a no-go now too. Best I can say is I would check for the big three and ensure you're getting them good: air (pretty dang easy to check), spark and fuel. If you're using starter fluid it sounds like you may not be getting fuel when you first go to fire it up. You mentioned carb, is this a 20R?
Old Mar 5, 2013 | 01:37 PM
83's Avatar
83
Looks like 22R, judging by the headlights.
If it's running rich, that's a good place to start..
Old Mar 5, 2013 | 01:43 PM
andy4x4's Avatar
bad fuel pump?
Old Mar 5, 2013 | 02:14 PM
mudbog01's Avatar
That's what I was thinking andy4x4. But I pulled the hose an started it an it was sprayin gas. So I think its good.. 83 ur saying I should try tunein up the carb more??
Old Mar 5, 2013 | 02:26 PM
83's Avatar
83
Always. I mean I guess if you know there is something not working correctly, and you have problems, why not fix what isn't working correctly?
Running rich isn't good for fuel economy, your cylinders, or your odor..
Old Mar 5, 2013 | 02:27 PM
andy4x4's Avatar
try and find a psi spec, i was fighting that in a rig for a while and it seemed to be working fine
Old Mar 5, 2013 | 03:09 PM
mudbog01's Avatar
Well I was looking at the fuel pump and I noticed that there was a spot for a vaccum hose but no vaccum hose on it.. is it suppose to be like that? And I can't figure out how to adjust the choke..
sonic concepts
Aug 16, 2025 03:13 PM
Regency
20
Jan 3, 2020 07:43 PM
Badger62811
Jun 26, 2015 09:26 PM
WI Girl
Jun 25, 2015 03:45 AM
slider417
Jun 22, 2015 10:18 AM
