Pre 84 Trucks 1st gen pickups
franken yota
Old Aug 9, 2013 | 05:53 AM
Firstgen_crawler's Avatar
Question franken yota
okay so i have a franken yota....the body is an 82, the frame an 85 or newer (IFS) and im trying to figure out what year the motor is, anybody have any insight on how to do this? its carbed so im thinking Pre-84
Old Aug 9, 2013 | 06:01 AM
Stetson_md's Avatar
They made carbed motors till 89 I belive but look at the valve cover to start if its straight it should be post 85 I'd its slanted towards the fire wall itshould bepre 85 check that then you can further narrow it down
The carb should have a date of mfg on it I believe but if its a Franken truck its probably beem changed
Old Aug 9, 2013 | 06:05 AM
Stetson_md's Avatar
This will also help https://www.yotatech.com/forums/f120...k-head-243586/
Old Aug 9, 2013 | 06:11 AM
redbayredneck's Avatar
It would be an '86 or newer frame for ifs. and carbed motors were standard into the late 80's
Old Aug 9, 2013 | 06:34 AM
Stetson_md's Avatar
81-87.5 carbs have a round electrical plug on them and 87.6-90 have a square plug so that might help you narrow down the date too
Old Aug 9, 2013 | 06:52 AM
Stetson_md's Avatar
Fergot to mention the carbs date code is right above the float window thing it should be somthing like 0A00
Old Aug 9, 2013 | 08:04 AM
alright ill see if i can check all that out, thanks for all the help guys
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
shredder4286
Oct 1, 2015 01:09 PM
