Pre 84 Trucks 1st gen pickups
1983 crankshaft pulley problem
Old Jun 2, 2013 | 10:57 AM
Abraham Contreras's Avatar
I just recently got my 22r rebuilt and yesterday we started putting the motor back together when it was time to put the crankshaft pulley back on we ran into a problem. The pulley wouldn't go in all the way as if the pump drive spline was stopping it. We have no idea what the problem can be all I know is we went from a single row to a dual row timing chain can this have anything to do with the pulley not properly fitting?
Old Jun 2, 2013 | 04:44 PM
slacker's Avatar
pullies are the same between the single chain and double chain .. only thing I can see impeeding "seating" of a crank pully are the keys in the crank and the keyway on the pully
Old Sep 19, 2013 | 08:06 PM
Tdub12's Avatar
crank pulley
I also ran into this problem it seemed the crank pulley have about 1/4 inch left and would not go any further. I put everything back in the way I found it for the oil pump. I was originally replacing a seal but now dont know what to do.. How would the key be placed on the balancer?would it be in the grove or slot or???
Old Sep 19, 2013 | 08:20 PM
Kiroshu's Avatar
Oil pump drive gear not installed correctly/not all the way installed...?
If I'm not mistaken the oil pump drive spline/gear is smaller on the dual row timing chain engines(Pre-84) than the single row timing chain engines.
Old Sep 19, 2013 | 08:38 PM
Tdub12's Avatar
Im gonna get into it tm and see wants going on.. I was thinkinking the same thing but then it started to get dark.. THANKS FOR THE REPLY
Well see wat happens Ill post results tm
Old Sep 19, 2013 | 08:41 PM
Originally Posted by Kiroshu
Oil pump drive gear not installed correctly/not all the way installed...? If I'm not mistaken the oil pump drive spline/gear is smaller on the dual row timing chain engines(Pre-84) than the single row timing chain engines.
That's exactly what was wrong with mine. Since I switched to the dual chain I had to buy a smaller spline because the original was just a little to big making my pulley not fit right.
Old Sep 20, 2013 | 09:25 AM
kawazx636's Avatar
The oil pump spline drive is definitely your problem. No dual row "kits" come with the shorter spline drive (that would make too much sense). LCE has them for about $30 or so. Should fix your problem
keithporter83
Jul 24, 2015 07:37 AM
yoterr
Jul 24, 2015 04:29 AM
jgallo1
Jul 22, 2015 04:21 AM
PlayAwhile
Jul 20, 2015 11:36 AM
dinks07
Jul 15, 2015 05:34 PM
