Pre 84 Trucks 1st gen pickups
Knuckle question
Old May 28, 2013 | 11:11 AM
CAdot's Avatar
Knuckle question
Old May 28, 2013 | 11:45 AM
jeremy.egli's Avatar
I did. Should've got the trail gear rebuild and eliminated that ˟˟˟˟ty felt seal.
Old May 28, 2013 | 12:06 PM
kawazx636's Avatar
Pack that beotch full of moly grease - inside and outside of the balls. You need it on the inside to grease the birfs and on the outside to grease the trunion bearings. When you pack the inside, just apply a good coat around the perimeter of the balls so that you won't push a bunch of grease into your axle housing when you slide your birfs in.
Old May 28, 2013 | 12:11 PM
CAdot's Avatar
Old May 28, 2013 | 04:16 PM
slacker's Avatar
yep , pack er' full of moly , and if you cut off the head of a bolt , it works as a perfect "alignment" tool to get the rest of the pieces and gaskets on . Get a few bolts in and then pull out the "tool" and replace it with a propper bolt , i know your done , but might help someone else lookin' in ..
Old May 28, 2013 | 07:20 PM
kawazx636's Avatar
Holy S**T that is a lot of moly! Have you had any issues with it oozing out? That was my concern with packing too much grease in there so I went with about 2/3 full figuring that I could alway pump in a little more if needed.
Old May 29, 2013 | 04:59 PM
slacker's Avatar
none what so ever (this is on my Trekker) .. it will go nowhere , unless the inner axle seals leak , then the gear lube will "wash" the moly out ..
this is also "hand packed" so there is room for air once it get used .. you can see all here http://toyotatrekker.proboards.com/t...er-axle-seals#
glowz825
Jan 25, 2022 09:28 AM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Ernie217
Aug 14, 2015 05:25 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
