Pre 84 Trucks 1st gen pickups
Thermostat seal
Old Jun 14, 2013 | 02:41 PM
83's Avatar
83
Thermostat seal
On my 83, there's a rubber gasket that slips on around the metal edge of thermostat.
My 78 didn't have one of these. It wasn't leaking. I cannot find this part anywhere. It's either "out of stock", or just non-existant.
Did 20R thermostats not have this rubber seal, in addition to the paper gasket?
Old Jun 14, 2013 | 03:36 PM
AaronM's Avatar
I had an 83 with a 22r and i want to say it also had the rubber seal around the thermostat. My 87 with a 22re definetely has one around the thermostat. It may be the difference in companies that make the thermostats.
Old Jun 14, 2013 | 05:58 PM
slacker's Avatar
20R was a paper gasket
Old Jun 14, 2013 | 09:05 PM
Yotayum's Avatar
My 94 22RE has an o-ring only; I haven't replaced my gasket on my 81 22R but from visually inspecting it this doesn't appear to have a paper gasket. Maybe try a 22RE o-ring gasket...... the thermostat housings look identical. I'm replacing my timing chain soon and plan on a new water pump and stat while I'm there, so let us know if it works, might as well get this stuff as well now....
Old Jun 15, 2013 | 04:30 AM
wyoming9's Avatar
Red face
thing is one never really knows just what water neck might be on the engine.
Put the gasket on if it does not leak your good to go.
Is there space for the rubber gasket on both sides of the thermostat housing??
Old Jun 15, 2013 | 09:01 AM
83's Avatar
83
Well, I guess it wasn't leaking with just the paper gasket and no o ring before, so hopefully it'll be good now. Thanks!
Old Jun 19, 2013 | 06:18 PM
83's Avatar
83
Aaaaannnnd...if the thermostat housing is leaking coolant, and the bolts are as tight as I dare to make them, where would you be looking for what I did wrong?
I laid the paper gasket flat on the bottom of the thermostat housing, put the thermostat on top of it, and then put the top of the housing on that.
Anything wrong there?
Old Jun 19, 2013 | 07:15 PM
slacker's Avatar
remember ..originally , the surfaces of the manifold and thurmo housing were machined flat , so a paper gasket would be fine ..
your unit is 30+ years old .. so you may have to "flatten" those surfaces again ..
checking with a straight edge would be your first step
Old Jun 19, 2013 | 07:23 PM
brianh699's Avatar
You can also try coating the paper gasket in a light coat of RTV, as long as you don't overdue I don't see it causing any problems.
Old Jun 20, 2013 | 06:08 AM
83's Avatar
83
Alright, thanks.
It's going to a shop today to take care of some things I can't do anyways, so I guess I'll have them check it out.
Old Jun 21, 2013 | 07:55 AM
83's Avatar
83
Here is what the problem was:
Like I mentioned, I laid down the thermostat gasket, then the thermostat. The correct way is lay down the thermostat, then the gasket on top of that.
Old Jun 21, 2013 | 05:27 PM
slacker's Avatar
yes .. that is correct .. if you look at the manifold , there is a machined surface for the thermostat to fit into .. then the gasket
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
White Stripe
Oct 6, 2015 10:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
