Thermostat seal
Thermostat seal
On my 83, there's a rubber gasket that slips on around the metal edge of thermostat.
My 78 didn't have one of these. It wasn't leaking. I cannot find this part anywhere. It's either "out of stock", or just non-existant.
Did 20R thermostats not have this rubber seal, in addition to the paper gasket?
I had an 83 with a 22r and i want to say it also had the rubber seal around the thermostat. My 87 with a 22re definetely has one around the thermostat. It may be the difference in companies that make the thermostats.
My 94 22RE has an o-ring only; I haven't replaced my gasket on my 81 22R but from visually inspecting it this doesn't appear to have a paper gasket. Maybe try a 22RE o-ring gasket...... the thermostat housings look identical. I'm replacing my timing chain soon and plan on a new water pump and stat while I'm there, so let us know if it works, might as well get this stuff as well now....
thing is one never really knows just what water neck might be on the engine.Put the gasket on if it does not leak your good to go.
Is there space for the rubber gasket on both sides of the thermostat housing??
Aaaaannnnd...if the thermostat housing is leaking coolant, and the bolts are as tight as I dare to make them, where would you be looking for what I did wrong?
I laid the paper gasket flat on the bottom of the thermostat housing, put the thermostat on top of it, and then put the top of the housing on that.
Anything wrong there?
remember ..originally , the surfaces of the manifold and thurmo housing were machined flat , so a paper gasket would be fine ..
your unit is 30+ years old .. so you may have to "flatten" those surfaces again ..
checking with a straight edge would be your first step
You can also try coating the paper gasket in a light coat of RTV, as long as you don't overdue I don't see it causing any problems.
kawazx636
Oct 6, 2021 03:03 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
