Pre 84 Trucks 1st gen pickups
Stick shift gets warm near transmission
Old Dec 2, 2014 | 10:53 AM
joesgarage's Avatar
STICK SHIFT GETS WARM NEAR TRANSMISSION. IS MY TRANSMISSION READY TO GO OUT? SOMETIMES TO WARM TO TOUCH.
Old Dec 2, 2014 | 12:27 PM
gillesdetrail's Avatar
Check transmission fluid level (remove fill plug, the fluid should be flush with the hole). Or drain and replace fluid if it's been a long time, even if it is clear (shouldn't be black, gray, dark brown).
Old Dec 2, 2014 | 03:36 PM
joesgarage's Avatar
I just had all fluids replaced. the only gear that sounds smooth is 4th gear. 5th gear gets a little weird.
Old Dec 2, 2014 | 06:59 PM
g3bill2's Avatar
Depending on how warm could just be a bad boot? Hot air from motor flows over that area and things will get a little warm but not as much in winter i'd think?
If you never checked the overlooked small boot on top of trans shift retainer that keeps dust out, good time... they crack from heat and all that shifting allowing dust and dirt to enter trans. Can't remember how the trasfer case is....
I made a shift boot for the floor out of soft black vinyl sewn on one side with a small 1/8" rope folded in at top and sewn to tie it tight to stick.
Just a thought, don't know but might consider adding some synthetic gear oil or an additive perhaps, more input?
Liadrin
Apr 25, 2022 02:54 PM
mskalmus
May 28, 2017 07:51 AM
Liadrin
Sep 1, 2015 06:44 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
crashburnoveride
Jul 10, 2015 06:39 AM
