Pre 84 Trucks 1st gen pickups
81 20r wierd weber problems
Old Nov 20, 2014 | 05:17 PM
rednek9's Avatar
So I was up the trails and on the last trail it started feeling like the carb was loading up or not getting fuel and I'd have too floor it to clear it out. So drove it 30 miles home fine and its gotten to where it will run fine cold with manual choke on, then warms up and dies with choke on or off.let it sit to cold again n does it all over. Once warm it starts for a sec then dies if I pump the pedal a ton it will run for a bit longer then die again???? Trying to get trail ready for Sat run. Thanks!!!
Old Nov 21, 2014 | 11:32 AM
gillesdetrail's Avatar
Maybe it is dirty, maybe it's the floats, maybe a clogged fuel filter too, with what you are describing it seems to run out of fuel.
Old Nov 21, 2014 | 02:46 PM
rednek9's Avatar
So I took the carb off n apart and stuck it in my carb cleaner at work and adjusted the floats by raising em s little bit and it at least starts and idles but if I giv it any gas what so ever it dies ?
Old Nov 21, 2014 | 02:48 PM
rednek9's Avatar
And I can see fuel spraying when I throttle up. Idk if I'm running to rich or too lean or what but it's weird this would randomly start happening without and progression
80Truck
Oct 12, 2025 07:25 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Logz808
Jul 26, 2015 07:09 AM
Yota.Jay
Jul 23, 2015 08:08 PM
