Pre 84 Trucks 1st gen pickups
Timing reading doesn't make sense on 20R engine--locking key missing?
Old May 28, 2015 | 03:59 PM
Dave80pickup's Avatar
Timing reading doesn't make sense on my 20R engine--has crankshaft pulley slipped?
The 79 20R engine I just put in my 80 pickup runs fine, but the timing reading doesn't make sense. It should show 8 BTDC. Instead it shows something more like 10 ATDC. But if you try to advance it to the correct setting, the engine is up to 2000 rpm before you're even close to TDC. I've never had the crankshaft pulley off the crankshaft on one of these engines, but from pictures it looks as if the two are keyed together with a removable key. If so, somebody may have installed it without the key and allowed it to slip out of position. Is the key removable?
Old May 29, 2015 | 05:27 AM
kawazx636's Avatar
moved to correct section --> Pre84 Tech
voiddweller
19
May 2, 2016 09:10 PM
rbravo1
Jun 29, 2015 01:34 PM
zytra
Jun 24, 2015 08:14 AM
Mr.Black
Jun 21, 2015 10:17 AM
