Pre 84 Trucks 1st gen pickups
odometer stopped working 81 pickup
Old Dec 29, 2014 | 08:00 AM
Mrpanda's Avatar
Once the cold hit back in November my odometer craped out at 38,400
not sure if I need to replace something or what to replace
Old Dec 29, 2014 | 11:45 AM
1st Gen Crawler's Avatar
Most likely the speed cable that connects the cluster to the t-case. Easy fix. Mine touched up against the exhaust when i was working so that toasted mine.
Old Dec 29, 2014 | 03:39 PM
gillesdetrail's Avatar
He is talking about the odometer, not speedo. I don't know if/how it can be fixed.
Old Dec 29, 2014 | 04:08 PM
When my Speedo quit it also stopped my Odometer for a few thousand miles while i fixed other things. Once i replaced the cable both started working.
Is your Speedometer still working as it should?
Old Dec 29, 2014 | 04:55 PM
Mrpanda's Avatar
yes speedo still works
Old Dec 30, 2014 | 05:08 AM
83Toyota88's Avatar
My odometer stopped working one day too. You need to pull the gauge cluster out and try to remove the odometer. More than likely everything has seized up and needs to be removed, cleaned, re-greased and put back together. I did that and mine works good now.
Old Dec 31, 2014 | 05:35 AM
81 Toyo's Avatar
They are notorious for eventually stop working....they were lubed at the factory 30 years ago and now they are dried up and slow down and eventually stop..even worse in cold weather...remove the cluster and spray some silicone between the reels, it helped mine..
irish_tyrant
Jul 6, 2015 11:22 AM
GorgeRunner
Jun 27, 2015 07:01 AM
gog1968
Jun 22, 2015 05:55 AM
mytruck
25
Jul 15, 2002 04:28 AM
