Pre 84 Trucks 1st gen pickups
stumped
Old Nov 11, 2014 | 10:08 AM
cyogi's Avatar
stumped
I have a 76 sr5 20r l put a delta 260 cam and new rockers, weber carb, header,k&n filter, pertronix ignitor and coil on it. It idles fine but when i excelerate under a load its misfires badly. My friend who is the mechanic and I can't figure it out! Any ideas!?
Old Nov 11, 2014 | 10:46 AM
Schnayke's Avatar
What weber are you running?
Old Nov 11, 2014 | 12:52 PM
gillesdetrail's Avatar
If you have a 32/36 and you haven't changed the jets there's your (or one) problem, if you have a 38 it should be performing good to great on the jets it came with.
Old Nov 11, 2014 | 01:24 PM
cyogi's Avatar
Im pretty sure its a 32/36 I had it on my 18rc for a couple thousand miles then it sat four a few years but was bought brand new.
Old Nov 11, 2014 | 01:49 PM
Schnayke's Avatar
yeah when you get a bigger cam that jet setup probably won't be able to keep up. I hear this is a common problem where people over cam but don't adjust the rest of the system to make up for the cam.
If I remember correctly my buddy had what he called a RV cam and went too a 36/38 on his.
Old Nov 11, 2014 | 02:06 PM
You can tune the hell out of a 32/36 also to run a larger cam (delta 260 is not so big) and supporting mods, it's just that at one point it becomes a restriction.
Your problem could be from the fact the carb sat 4 years, depends on how it was stored, and/or incorrect jetting, amongst maybe other things we don't know. Spending thousands on engine work and parts and not spending a couple hours and 50$ on a jet kit to make it run good is a waste! There are many good threads on how to tune your 32/36 and specific rules to follow with them i.e fuel press, throttle screw setting can't be open too much, etc. Good books too.
Old Nov 11, 2014 | 02:08 PM
And I don't think they had sr5 in 76? I thought it started in 81, maybe 80.
Old Nov 11, 2014 | 02:10 PM
cyogi's Avatar
That's it! A delta camshaft rv 260, it is supposed to be a mild upgrade. So you think I mite need bigger jets in carb?
Old Nov 11, 2014 | 03:54 PM
There is an easy way to find out by how many turns out your mix screws are out, here read this thread, after that you'll be a pro at carb tuning and your truck should run pretty strong.
https://www.yotatech.com/forums/f114...tuning-261129/
rubrsidedwn
Jul 7, 2016 07:28 PM
zanzabar0
Oct 11, 2015 02:56 AM
dzldust
7
Oct 6, 2015 05:39 AM
toyotafreak98
Sep 10, 2015 02:57 PM
stock87yota
Jul 31, 2015 10:08 AM
