Pre 84 Trucks 1st gen pickups
Water plate
Old Jan 1, 2015 | 01:01 PM
demo913's Avatar
Water plate
Hello from NC. I have a coolant leak from the block plate under the intake. I tried to tighten the bolts and one broke off. What exactly does this plate do and how to I stop the leak once I get the bolt out fingers crossed.
Happy new year also
Thank You
Matt
Old Jan 1, 2015 | 01:20 PM
wyoming9's Avatar
Red face
Welcome to Yota Tech!!
Just what engine are you speaking about it is a Toyota it could have any engine installed by this stage of it`s life.
Old Jan 1, 2015 | 01:21 PM
demo913's Avatar
My bad. Its a 20r in 76 pickup.
Old Jan 1, 2015 | 02:04 PM
jaysson_2012's Avatar
I would use a gasket sealer. What part of NC you from?
Old Jan 1, 2015 | 02:09 PM
demo913's Avatar
I am in Charlotte. Why is this plat there. Seems like a problem that will likely just come back.
Old Jan 1, 2015 | 02:28 PM
I know water runs through the intake for emissions purposes I believe. Why that specific plate is there I dont know. Other than for a place for the heater core supply to come from.
Old Jan 1, 2015 | 02:36 PM
demo913's Avatar
Is there a way to bypass/delete this plate?
Old Jan 1, 2015 | 03:51 PM
I don't think there is. You can get a water block plate from LCE, but that does not stop water from flowing through it. I will hopefully be pulling my intake to fix a water leak on that port in between the intake. I'll get a better look then.
Old Jan 2, 2015 | 12:59 PM
gillesdetrail's Avatar
Hi demo, the reason why the coolant passes through the intake the way it does is to prevent carburator freeze off in the cold climate winter like we have here, it is also to help the engine run better sooner because the hotter the intake manifold, the better the fuel atomization, and the better/more efficient the engine will be, it is kind of a anti-polution thing but also a fuel economy thing, so removing it will mean the engine will take longer before you can turn the choke off, and may reduce mpg a bit. On a side note it can also increase power a little but nothing you can feel! I used fipg to seal that plate because I had a leak too with the gasket, don't overtighten or you can bend the plate.
Old Jan 9, 2015 | 11:05 AM
mtrdud's Avatar
Toyota Black FIPG has never failed me.
Old Oct 31, 2015 | 11:00 AM
skooterbumm's Avatar
does anyone know where to get this gasket, or a part number that i could use to locate... all i can find is one in a complete set, or head set... i dont need all those gaskets.
Old Nov 2, 2015 | 09:54 AM
kawazx636's Avatar
That plate also houses the CMH (Cold mixture heater) which is an electric "hot plate" that heats up during warm up to help heat the fuel mixture and improve atomization while the truck is warming up. Once the coolant reaches operating temperature then the CMH shuts off and the coolant heat takes over. The CMH can be eliminated and LCE makes a block off plate for under the intake that allows for this. Water still passes through the intake, but the CMH is deleted.
I'm assuming that you have a 20R in that truck so this is the block off plate that you would need:
http://www.lceperformance.com/Water-...-p/1032032.htm
LCE says that the gaskets are no longer produced so they recommend using Ultra Grey RTV to seal it. You should be able use Ultra Grey on your stock plate as well if you plan on using it.
Old Nov 4, 2015 | 05:30 AM
jimbyjimb's Avatar
The guys covered it with the block off plate and rtv but I'll add that the 74-78 truck uses a water choke on the factory carb. If you don't have a factory carb, don't worry about it. The factory carb really sucks on the 20R.
Old Nov 19, 2015 | 05:29 AM
thanks guys LCE had what i needed
Old Nov 23, 2015 | 10:40 AM
mudmaster's Avatar
I got the gasket at my local dealer. That was more than 10 years ago though........
Sep 4, 2015 09:27 AM
Iceman4193
Aug 28, 2015 08:43 PM
TJWilly
Jul 31, 2015 02:05 PM
jjrbus
Jul 19, 2015 02:06 PM
Snort
Jul 19, 2015 07:03 AM
