Pre 84 Trucks 1st gen pickups
anchor and shackle bolts?
Old Nov 20, 2009 | 01:51 PM
Al's Chop Shop's Avatar
what size are the front anchor and shackle bolts on these rigs? i'm hoping 9/16" so i don't have to buy new bushings when i go with the wag spring swap.
Al
Old Nov 20, 2009 | 05:46 PM
dropzone's Avatar
Fossilized
Al: if you don't get an answer tonight I will get you one when I get home...but I know it is gonna be metric...about 14mm which is pretty close to 9/16's
~Robb
Old Nov 20, 2009 | 05:57 PM
4Crawler's Avatar
Assuming you mean spring hanger and shackle bolts, typically 18mm for all the above on the early trucks, and all odd-ball too, none are true bolts with a head and threads the same dia. as the shank of the bolt. So you'll find they have 14mm threads on the end with the nut, but 18mm inside the bushing.
Old Dec 5, 2009 | 09:10 AM
my concern is that the bolts will be too big or too small for the bushings in the wag springs i'm swapping up front.
if the inside of the bolt where the bushing sits is 18mm i'm going to need larger bushings.
anyone have a good source for rubber spring bushings?
Al
Old Dec 5, 2009 | 05:32 PM
slacker's Avatar
typically it is , toyota sizes are all metric .. US bushing manufacture are all SAE standard .. unless you "sleeve" the bushing .. you will have slop
Old Dec 7, 2009 | 12:08 PM
yep, thats why i wanted to make sure to get the right bushings or it will wander worse than before!
now i'm on the hunt for 18mm inside, 1 1/4 and 1 1/2 inch outer sleeved bushings.
Al
Old Dec 7, 2009 | 12:35 PM
91Toyota's Avatar
Did you ever get your slow warm up problem fixed?
Old Dec 8, 2009 | 01:12 PM
yeah i did, it turned out to be a faulty AND wrong temp thermostat. got it swapped out with a 195 and things were great, til the old radiator gave way and it started overheating. it sat for a few years so there was a lot of junk that got loosened up. tried flushing it twice without luck, so i put in an aluminum radiator, and it runs perfect temp now.
Al
punks_is_4x4
May 31, 2016 06:03 AM
Corvoid
Sep 14, 2015 10:10 AM
Pocoyota
Sep 8, 2015 02:41 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
Jwp1
Sep 6, 2015 11:03 AM
