Pre 84 Trucks 1st gen pickups
83' Front axle trouble...
Old Nov 19, 2009 | 09:00 PM
gshum3k's Avatar
I've got an 83' and when I lock the hubs and put it in 4 wheel drive it makes a loud clacking noise on the passenger side of the truck and i can feel it each time it clacks. When i go faster the clacking speeds up as well. Any idea what it is or if there is something i can do to find out? I've got some time off from work this next week and I'd like to fix the problem before the snow starts to fall.
Thanks.
Old Nov 19, 2009 | 10:56 PM
dropzone's Avatar
Fossilized
welcome to YT...
it sounds like you may have either a busted hubring (inside the locking hub)
(in case it is the hub: https://www.yotatech.com/forums/f116...ferrerid=12218 )
or a broken birfield joint (kind of like a CV inside the knuckle ball)
sounds like a teardown is in the works for you...
4cRAwler's SA axle rebuild link: http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
here is a link to a factory service manual that will have step by step on the tear dow:
http://www.ncttora.com/fsm/index.html
it is a 58 MB download but well worth it...
Good luck!
Old Nov 19, 2009 | 11:01 PM
AZkid's Avatar
Old Nov 21, 2009 | 11:05 AM
gshum3k's Avatar
Thanks for the info! Looks like I'll be getting my hands greasy this weekend.
Old Nov 21, 2009 | 11:45 AM
82blueyota's Avatar
it could be the double cardan joint in the drive front drive shaft it has a collar in it that can come loose and make a clacking noise
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Cabell
Jul 24, 2015 12:14 PM
