Pre 84 Trucks 1st gen pickups
One wire alternators
Old Aug 25, 2009 | 03:56 PM
yota7357's Avatar
Thumbs down One wire alternators
I"ve heard a lot of people talk about putting a chevy one wire alt. in toyotas. I need to know what year Chevy you can find these on, and if there is someone who makes adapters to mount them on a 83 toy with a 22R.
Old Aug 25, 2009 | 04:01 PM
jeremy9allen's Avatar
I'm not sure about fitting the alternator, but the alternators found on older small blocks are the ones for running a one wire set-up.
They mount the same way the toyota one does One long bolt on the bottom for the pivot, and one that threads into the ear.
I am running a one wire set-up on a boat with the old alternator off my 85 c10 I had.
Old Aug 25, 2009 | 04:24 PM
kdo58's Avatar
search for Aron
on this site, he make the adapter was $50.
he you read the fax section this info is all covered. I have done it and love it.
Old Aug 26, 2009 | 12:15 PM
yota7357's Avatar
I found the brackets for sale and I am going to buy them but when I go in to buy one what should I tell them to look under.
Old Aug 26, 2009 | 12:33 PM
kdo58's Avatar
this is what i did to mine,
http://www.rocketcityrockcrawlers.co...%20Project.pdf
Old Aug 26, 2009 | 10:30 PM
refried's Avatar
BAD IDEA!
Marine (boat) alternators are sealed to prevent sparks (they have screens over any opening and different bearings). Running one in a boat is a good way to blow up, any fuel vapors that lay in the bilge could be ignited by an automotive alternator or starter. Threre's a reason boat eletrical stuff is expensive.
Old Aug 27, 2009 | 03:27 AM
Originally Posted by refried
BAD IDEA!
I was not aware that the original alternator was sealed like that. They looked identical.
I had always run the blower for a few minutes before starting the motor. I guess I will have to fork out the money for the correct one.
Old Aug 27, 2009 | 05:23 AM
ozziesironmanoffroad's Avatar
when i do the GM one wire swap, ill be doin a writeup .
one thing i dont get though.... can you use the toyota alt. belt? or do you have to use the chevy belt?
or do you just swap the pulleys?
or am i just thinkin weird?
Old Aug 27, 2009 | 05:48 AM
kdo58's Avatar
i was able to use my stock belt. it was a tight fit, on one of the right ups it gives a part # for a belt that is 1" longer than stock.
Old Aug 30, 2009 | 08:55 AM
rottenagenda's Avatar
or you can just buy a 55amp stock one from napa. stead giving your self a headache buy a good battery.
Old Sep 7, 2009 | 07:25 PM
kdo58's Avatar
here is a good write up
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
msane99
Jul 17, 2015 10:13 AM
colinmil
Jul 6, 2015 04:03 PM
