Pre 84 Trucks 1st gen pickups
Tune up blues
Old Nov 6, 2009 | 09:59 PM
duneyota's Avatar
Tune up blues
the truck was running fine,and then came the minor tune up consisting of new spark plugs,plug cables,and cap and rotter. Now shes is running a little hard with a minor studder only when cold.
i am thinking maybe a bad plug,but not sure where to start my trouble shooting.
thanks in advance...Rick
Old Nov 6, 2009 | 10:34 PM
minimudder's Avatar
What type of plug did you use? From what i gather, the oem ngk or denso plugs are the best
Old Nov 7, 2009 | 04:40 AM
Gov't Mule's Avatar
did you double check the gap on the plugs before you put them in?
Old Nov 8, 2009 | 12:03 PM
duneyota's Avatar
the first plugs i used were ngks unfortunately my gap was way off, recommended gap is 32..i had them at 38..lol.
so i bought a new set of plugs this time gaped correctly, the studder got better,but still not running how she use to.
any one think maybe a carb problem?
Old Nov 11, 2009 | 09:20 PM
rowdy235's Avatar
Could be a carb problem but I'd look other places first.
Fuel Filter?
Timing?
Air Cleaner?
Seems like your symptoms are related to the tune-up, but sometimes things just happen at convenient times
Old Dec 10, 2009 | 05:23 PM
duneyota's Avatar
well i have changed the distributor,new cables again and checked the timing.She has improved a bit, but still not running like she use to.
i was told that the coil might give me studder miss at high rpms.
any ideas any one.
Old Dec 10, 2009 | 05:29 PM
Teuf's Avatar
Defies logic doesn't it, a harmless simple replacement n bang zoom, prob's. You said it was subtle, but them are the worst.
Old Dec 10, 2009 | 05:32 PM
xfactor203's Avatar
You say you bought another set of plugs to solve the gap issue? Are you relying on pre-gapped plugs to be correct? You should double-check anyway. Sorry if you already know this. All plugs torqued to spec and wires on securely? It's often the easy things. . .
Old Dec 10, 2009 | 05:47 PM
Gov't Mule's Avatar
Check the gap on the coil pickup (sits under your distributor rotor) Should be right around .006 if I recall correctly.
Old Dec 10, 2009 | 07:36 PM
maistroyoda's Avatar
If your truck was running good before you did this "tune up" then there's a good chance it was something you did. Go back and double check everything you did
ashamsuddin
17
Jul 22, 2024 03:59 AM
ladybugRC
458
Aug 21, 2020 10:41 AM
the_supernerd
Oct 1, 2015 09:20 PM
1985 4Runner
Sep 30, 2015 10:17 AM
charlie_fong
Sep 27, 2015 10:06 PM
