Pre 84 Trucks 1st gen pickups
1981 Toyota 4x4 dash modification
Old Sep 30, 2009 | 11:48 AM
russtri's Avatar
I am wanting to put in a older model Nakamichi pull out stereo into my 1981 4x4 truck. I know some mods. will have to be done. I currently have a stock stereo and the stock cassette right above it. I will be having to cut the plastic dash. What is the best way to do this?
Old Sep 30, 2009 | 12:07 PM
yota81's Avatar
a small cut off tool, such as a dremel, will be the best for the plastic...you may have to cut some supports out behind the dash panel to fit the width.
Old Sep 30, 2009 | 01:16 PM
tj884Rdlx's Avatar
if you haven't cut plastic with a dremel, you don't know what you're missing. i've done a lot of stereo installs using razor knifes, hacksaw blades with tape around one end, etc. a dremel goes through plastic like butter if you crank up the rpms and let the cutting wheel do the work. be prepared tho, hot liquid plastic will spray and burn mildly. it's irritating.
HOWEVER, i just looked at a picture of a dashboard for an 81 for sale on fleabay. the pic shows a radio on bottom and a pocket above. are you sure the pocket above isn't a DIN size hole? you may be able to pull that cassette and its brackets, and mount the sleeve for the pullout nakamichi right in that hole without cutting. check it out first. it might require just some filing of the hole to fit the sleeve, instead of major cutting. and then you can leave the factory radio alone.
Old Sep 30, 2009 | 03:02 PM
rowdy235's Avatar
You may not want to hear this, but....
Stock Umolested Center Bezels are getting more and more rare as time goes on. My truck, for instance, doesn't even have the original one, its cut from a piece of plexiglass.
Now, if it were me, I would remove the whole bezel, and put it some chrome diamond plate or something like that, would make it look way cooler, plus for the price you could get out of the bezel, you could probably pay for the diamond plate.
That said, a dremel does work great for cutting plastic.
Old Oct 1, 2009 | 04:14 PM
yota81's Avatar
^ this is true. modifying the stock bezel for a new cd player leaves it looking messy, and the supports behind have to be cut out. sell the original dash and make a new one. probably make enough money with the sell to make whatever you want.
Old Oct 1, 2009 | 05:01 PM
slacker's Avatar
true dat !!!
If your dash is in great condition .. the DONT CUT IT !!
there are tones avalable at the wreckers .. so go get one of those , and keep the original in good shape .
if it's already been "hacked" up .. then cut away
Old Oct 2, 2009 | 02:12 PM
Sked's Avatar
How much would you guys pay for a mint dash and pad anyways? They are rare as crap around here not even a single toyota older than 85 in any wreckers.
I drove up north to Mackenzie and picked up a parts truck and it had a mint pad and dash... couldnt believe it and paid 300bux
Old Oct 2, 2009 | 04:36 PM
slacker's Avatar
I might be interested ...
email me cj@toyotafiberglass.com
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
crash
21
May 28, 2005 10:11 AM
Corey
24
Jul 15, 2002 07:53 PM
Krash
10
Jul 13, 2002 09:21 PM
