Pre 84 Trucks 1st gen pickups
Wiring Question
Old Dec 8, 2009 | 01:52 PM
CrazyEye's Avatar
Wiring Question
I have an 83 Shortbox SR5 4x4. I am in the process of wiring up a new fuse box to it from another 83. Everything is colored coated and fairly simple to wire up but there are 2 big black wires with yellow stripes are these just grounds? can they be switched? There are also 3 big white wires can these also be crossed up. I really dont want to pull my wiring harness apart and trace the wires. Thanks in advance
Old Dec 8, 2009 | 02:49 PM
CrazyEye's Avatar
Anyone know? Im trying to get this done before the sun goes down...
Old Dec 8, 2009 | 06:31 PM
yota8083's Avatar
The big white wires are ground wires. I am not sure on the black with yellow. Sorry this wasnt before the sun went down.
Old Dec 8, 2009 | 08:41 PM
CrazyEye's Avatar
Thats okay man, no biggie I have drop lights. Thanks for the info, Its greatly appreciated.Anyone know about the black with with the yellow stripe?
Old Dec 9, 2009 | 09:58 AM
CrazyEye's Avatar
bump..
Old Dec 9, 2009 | 10:38 AM
83's Avatar
83
I'll try to remember to look at my 83 FSM tonight. Sometimes the colors are different...even between the same year, but hopefully we can figure it out.
Old Dec 9, 2009 | 12:07 PM
CrazyEye's Avatar
great, thanks alot.
Old Dec 9, 2009 | 12:34 PM
corteznewbie's Avatar
well i have a wiring question my horn stopped worken all fuses good but not seeing a horn relay or a spot for one. any clues?
Old Dec 9, 2009 | 12:52 PM
83's Avatar
83
You should start your own thread since this kind of hijacks crazyeyes. But it's usually the contacts right under the horn buttons that wear out. Search, I know it's been covered on one of these Toyota sites...but I don't feel like searching for you
Old Dec 9, 2009 | 07:02 PM
yota8083's Avatar
If I am looking at the schematic correctly it looks like there is a black with yellow strip wire going to the light switch. If this is the one your talking about it looks like they just tie it in with the ENG and Wiper fuses on the fuse panel. Maybe 83 can confirm this.
Old Dec 9, 2009 | 07:39 PM
CrazyEye's Avatar
Yea thats what they are hooked to on the fuse box, just wasnt sure which one was which coming from the harness. Or if it would hurt if I mixed them up by accident. I have no power to the truck so I cant really test them, and the dash it out at the moment, So I wanted to wire this up before I put the dash in. Not a whole lot of room to work with as it is. After I get this wired up I am putting the dash in and dropping my motor in this weekend. Thanks for all your help guys
Old Dec 10, 2009 | 05:33 AM
83's Avatar
83
Forgot to bring my FSM in this morning...I'll grab it on my lunch break. Sorry usually when I leave work I do my best to not think about anything that happened there.
Old Dec 10, 2009 | 12:02 PM
CrazyEye's Avatar
Cool, thanks alot 83
Old Dec 11, 2009 | 10:52 AM
83's Avatar
83
Ok....yes whites are definitely grounds so they shouldn't matter (as far as where...as long as they ground). Any black yellow that I see in the wiring diagram goes to the 15amp engine fuse, so as long as they go to that, I think you're good. Looks like it's emissions, fuel cut solenoid, and maybe some ignition stuff, but either way, the only b-y wires I see going to a fuse, go to the 15amp engine fuse.
Let me know if you need more info.
Old Dec 11, 2009 | 07:02 PM
CrazyEye's Avatar
Thank you, much appreciated.
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
