Pre 84 Trucks 1st gen pickups
sway bar
Old Oct 19, 2009 | 08:28 PM
corteznewbie's Avatar
sway bar
any one know if the 82 4x4 had a sway bar? because mt steering is kinda out of wack. when i drive it wonders
Old Oct 19, 2009 | 08:56 PM
toyota4x4907's Avatar
An anti-sway bar is not gunna make you wander. Anti-sway bars help keep body roll down when cornering. You probably want to get an alignment and check your front brakes.
Old Oct 19, 2009 | 08:59 PM
algranger's Avatar
Yeah you need an alignment, its easy to do yourself its easy with a straight axle, just use a tape measure. Bring the fronts together about 1/4"
Yes your truck did come with a sway bar but it doesnt really do anything, your old springs get tired and stiffen up and give the same effect
Old Oct 19, 2009 | 09:04 PM
what about adajusting the gearbox
Old Oct 19, 2009 | 09:20 PM
algranger's Avatar
Why would you want to do that?
By adjusting i assume you mean reindexing...?
Old Oct 19, 2009 | 09:25 PM
well when i driv feels like the front end is floaten. and theres sum play in the steering when i'm park and turn the wheel
Old Oct 19, 2009 | 09:49 PM
4x4YOTA's Avatar
check your knuckles make sure there not loose and your wheel bearings... make sure the preload is right
Old Oct 19, 2009 | 09:56 PM
peow130's Avatar
Check balljoints, though it could be your gearbox.
Take it to an alignment shop.
Old Oct 19, 2009 | 10:02 PM
knuckles been rebuilt last year cost me 700 bucks they said everything to specs
ladybugRC
458
Aug 21, 2020 10:41 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
potatopants
Sep 15, 2015 06:26 AM
