Pre 84 Trucks 1st gen pickups
horn no workie
Old Dec 9, 2009 | 02:45 PM
corteznewbie's Avatar
horn no workie
the horn on my 82 4x4 stopped worken. not seeing a horn relay or any bad fuses any idea????
Old Dec 9, 2009 | 02:46 PM
81 yota 4x4's Avatar
who needs a horn?
Old Dec 9, 2009 | 03:22 PM
me do and what yr cj alt you put on ya truck
Old Dec 9, 2009 | 03:36 PM
toyodually's Avatar
i dunno if your horn setup is the same as my 87, but under the wheel is this pin on a spring that touches a a circle deal on the steering wheel, that could be broke.
Old Dec 9, 2009 | 03:46 PM
1990yota-pickup's Avatar
take. i hot wire striaght from the battery postive and a touch the power wire into the horn, the horn should complete a circuit if the horn is properly grounded to the chassi.. so check for alot of rust and nasty on the mounting bolts..
Old Dec 9, 2009 | 04:33 PM
i put a new horn and ground is good but no power to the leads in the wheel
Old Dec 9, 2009 | 04:53 PM
davo247d's Avatar
my old truck the horn would only work if the stearing wheel was upside down haha u should of seen me when some idiot was about to back into me
Old Dec 9, 2009 | 05:07 PM
it was out of an 83
Old Dec 9, 2009 | 07:00 PM
4Crawler's Avatar
Probably the reason for that is the horn switch on the steering wheel is connected to ground and it is that ground connection that provides ground to the horn (which should have constant power to one lead) to turn it on. So the horn itself is floating and not electrically connected to the chassis ground.
Old Dec 10, 2009 | 01:15 PM
look in the toyota manual.. it will help, or just run a new relay and a seprate push button horn switch and mount it on the dashboard somewhere.. good enough to pass dot inspection..
Old Dec 10, 2009 | 02:21 PM
VToyota's Avatar
Had this same problem on an '89 4Runner. If they are the same there will be a slip ring on the back side of the steering wheel that allows the spring loaded contact to complete ground as you turn the wheel (when you push the horn). There is no power to the steering wheel. Mine was worn to the point that it no longer made contact- I shimmed the round collector with a couple small washers and all was good.
Old Dec 10, 2009 | 04:07 PM
just get in there, and tinner around with it.. un tell it stresses you out.. then call a couple maintenance shop so the can make you feel good about how much they want to charge you.. (and tell them to screw off, and hang up on them) that will give you the mottovation to fix it your self.
mussy01
Dec 13, 2016 08:20 PM
xzen73x
Sep 14, 2015 03:00 AM
Curbstomp336
Aug 30, 2015 07:20 AM
ToyoToler
Aug 8, 2015 08:43 AM
jimkoz26
Aug 5, 2015 03:15 PM
