Pre 84 Trucks 1st gen pickups
Hysteer questions
Old Jul 22, 2009 | 06:29 PM
Derek92's Avatar
Question Hysteer questions
Im ready to buy Hysteer from TG and I cant figure out which pitman arm to get. Im planning on running rears up front that will probably get me 3-4 inches of lift. I was wondering if anybody is running the flat pitman arm and why. I read on here that the arm can hit your springs if its not the right one.
I might sound stupid for asking this but im pretty confused.
Old Jul 22, 2009 | 06:33 PM
waskillywabbit's Avatar
Depends on how you mount your IFS box as to which pitman arm you need.
And you should buy your junk from me.
Old Jul 22, 2009 | 09:14 PM
dropzone's Avatar
Fossilized
Originally Posted by waskillywabbit
The IFS box mount is pretty simple. Cut the fender well so you can easily access the PS box area like shown in my pictures posted already and then push the box all the way forward until it is on the core. Angle it so the holes line up on the frame in the center and then test fit your mounting plates. Tack weld and test fit again to make sure the pitman arm clears and weld out.
what you don't want to have happen when you install your high steer:
Originally Posted by 98taco4x
oh and make sure that your drag link clears your tierod.
Cause you don't want this.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
