Pre 84 Trucks 1st gen pickups
front axle
Old Jul 28, 2009 | 06:18 PM
82odyota's Avatar
front axle
anyone have anyidea why my front end i think axle clicks when i turn one way to another and bumps? sounds like an axle shaft hitting a retaining ring? anyone else had this problem also will highsteer take away the grabby pull i get on uneven roads
Old Jul 28, 2009 | 07:17 PM
dropzone's Avatar
Fossilized
stripped a hub ring or maybe broke a birfield...39.5's aren't easy on them:
Old Aug 14, 2009 | 05:14 AM
dropzone's Avatar
Fossilized
Originally Posted by Transmission Frank
definitly a worn constant velocity joint aka as rzeppa joint. I would recomend filling the knuckle with a #0 sodium based grease to ensure longevity . I have some available if interested
Frank you are correct that a Toyota used a Rzeppa Joint however Toyota folks traditionally call them a Birfield Joint. Are you an Amsoil dealer or something?
Sounds like you are hawking a product, you should consider becoming a sponsor of this forum. My guess is that some cool lube won't fix a busted part.
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Cabell
Jul 24, 2015 12:14 PM
