Pre 84 Trucks 1st gen pickups
82 4x4 front wheels not engaging
Old Nov 5, 2009 | 06:04 PM
markymark116's Avatar
i have a hacked up 82 trail rig, manual locking hubs, which are locked, but front wheel is not engaging. buddy said it's probably the splines on the front drive shaft (slip yoke). i don't know much about these
Old Nov 5, 2009 | 06:09 PM
dropzone's Avatar
Fossilized
welcome to YT. you can test your front driveshaft but twisting both ends...it would be pretty obvious if your DS was fubar.
Which front wheel is not engaging?
I am thinking your buddy meant to say that the splines in the hub are not engaging. Could be a busted hub ring.
Old Nov 5, 2009 | 06:10 PM
xjdubber's Avatar
i'd bet on a busted hub. got some used warn ones that should fit that.
Old Nov 5, 2009 | 06:14 PM
camo31_10.50's Avatar
or ya could just rebuild yours....its SUPER easy..you take it apart....clean everything..put everything back together with some greese from the rebuild kit..and then install new gaskets...BANGO! problem solved...
or ya could just get some WARN hubs (brand new) from autozone or oreiley's..
Old Nov 5, 2009 | 06:17 PM
he was thinking the splines were wore out in the front drive shaft, but the shaft was spinning when the wheels were rolling. i went to put it up on my trailer. with my other rig, i put the front wheels on the trailer, and use 4 wheel to walk up on. this one, the rear tires were spinning in the grass, and the fronts weren't moving
Old Nov 5, 2009 | 08:09 PM
xjdubber's Avatar
hows your truck running.
Old Nov 5, 2009 | 08:18 PM
uhh.......good?..do i know you..LMFAO..just wonderin man..lol
it's runnin good..but i just nee to fine tune the carb a little now..LOL
Colington
Mar 8, 2020 09:51 AM
Nickdigg
Jul 7, 2015 06:04 AM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
zd92655
Jul 5, 2015 04:25 PM
