Pre 84 Trucks 1st gen pickups
83 Sr5, where does this wire go?
Old Nov 14, 2009 | 08:06 AM
heatwave's Avatar
Looked thru all my diagrams, what does this wire connect to?
Thick black w yellow trace, white wire other side of connector.
Passenger side fenderwell, 83 4wd sr5.
Old Nov 14, 2009 | 08:10 AM
pennywize's Avatar
not sure offhand, i'll check out my '82 sr5 later today and let you know if i see anything like it on mine.
Old Nov 14, 2009 | 04:28 PM
slacker's Avatar
thought about your PM for a bit ...
depending on your vehicle spec. might be the fuel heater in the bottom of the intake manifold ...
Old Nov 15, 2009 | 12:04 AM
pennywize's Avatar
hmmm i didnt see any black-yellow wire that connects to a solid white wire on my 82. not sure what its for. i'll try and get a better look at it next week if you still need to know.
Old Nov 16, 2009 | 06:05 AM
83's Avatar
83
Not what you want to hear, but there's GOT to be some connectors in the engine compartment that aren't hooked up to anything right now that you can find...that ought to get you started. If I find the time and remember, I'll check my truck out today. Not an SR5, but I doubt I'd be missing that many connectors on the pass side with a base model. They weren't that different back then.
Old Nov 16, 2009 | 06:22 AM
slacker's Avatar
there is also the anti deiseling selenoid on the carb .. I believe it has that connector
Old Nov 16, 2009 | 01:13 PM
maistroyoda's Avatar
Ok I have the exact same truck...found that exact wire in your pic. It goes connected under your intake. I took some pics just trying to upload hold on a sec
Old Nov 16, 2009 | 01:27 PM
Old Nov 16, 2009 | 01:28 PM
Old Nov 16, 2009 | 01:31 PM
Old Nov 16, 2009 | 01:34 PM
The last pic is from the underside. You can see the white white in two places. The top one is where it connects to the bottom of your intake.
Old Nov 16, 2009 | 03:37 PM
heatwave's Avatar
thanks for the replies,
Truck is not running the stock manifold, and the damn wire was just hanging there. Im chasing down some wiring problems to get this thing back on the road.
Old Nov 16, 2009 | 06:56 PM
If you're not running the stock manifold then you probably don't need to worry bout it. Unless your current manifold has a place to hook up this particular wire.
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
88yodabasket
Jul 13, 2015 01:32 PM
Rkellerman
Jul 12, 2015 08:42 AM
