Pre 84 Trucks 1st gen pickups
80 tranny-clutch-slave Question???
Old Nov 6, 2009 | 06:29 AM
69800's Avatar
On my 80 4x4 which is new to me, the previous owner just put a new r22 and clutch in.. clutch works fine. But I see the slave is leaking (its new) and its adjusted all the way out to the last thread. I have about 2 inches of free play on the pedal as it is.
Is there a different slave with a longer throw or might I have the wrong clutch fork? I am getting ready to put in a rebuilt L-52 tranny and want to have all of the correct stuff for the clutch before I do it. l
thanks
mark
Old Nov 6, 2009 | 08:26 AM
83's Avatar
83
Definitely a Marlin forum question
If I had a 22R and L52 trans, I'd want to the clutch fork that came with them. Not sure if it changed from the 20R and L43 or whatever or not, but it may very well have. Search is your friend, I'll bet this question has been covered.
Get a manual and make sure the pedal and master cylinder are adjusted correctly, too. If that all checks out, you could have the wrong clutch fork, throwout bearing, maybe the clutch fork is bent, etc.
Old Nov 6, 2009 | 09:22 AM
69800's Avatar
I cant believe there would be any difference on clutch fork. the slave, fork and throwout bearings all work the same regardless of which tranny is bolted up behind them
mark
Old Nov 6, 2009 | 01:49 PM
83's Avatar
83
You can believe or not believe whatever you want. You asked in your first post if you might have the wrong fork.
Clutch forks changed through the years. Pretty much any hyrdaulic clutch/tranny/engine works the same from one brand vehicle to another. Why don't you try using a Ford clutch fork and see how it does?
A 20R engine with a L43 tranny behind it may well use a different fork, throwout and pilot bearing than a 22R with an L52 behind it. And if you're mixing and matching, there is a method. I can't remember if you pick the throwout bearing/clutch fork etc. to match the engine, or the tranny, but in some applications it does matter.
Old Nov 6, 2009 | 02:05 PM
peapicker's Avatar
from what I understand u use the clutch, p plate and pilot bearing that is matched to the engine. and match the throwout bearing and fork to the tranny and all should be well
Old Nov 6, 2009 | 02:41 PM
83's Avatar
83
I keep trying to find the thread on Marlin where someone is asking what shift fork etc. to use when matching a 20R to a new tranny(I think), and Marlin answers him. Slightly different than this question, but along the same lines. Marlin site seems to be down though.
Hopefully you're right, that seems like it would make sense.
Old Nov 6, 2009 | 04:06 PM
69800's Avatar
I talked to the guys at marlin and the told me every thing I need. I forgot the bell housings are different.. If I use their tranny it come with every thing buy a clutch and shifter and they have those also. Plus I got my current clutch all bled and adjusted. work good
thanks 83
Old Nov 7, 2009 | 04:32 AM
peapicker's Avatar
awsome! btw, good lookn truck in your avitar!
Old Nov 8, 2009 | 02:53 PM
69800's Avatar
I got lucky ;.. this 80 has had a pretty soft life. I wish i could post a picture of the engine bay
mark
Old Nov 9, 2009 | 05:22 AM
83's Avatar
83
Nice! Glad you got it straightened out.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
