Pre 84 Trucks 1st gen pickups
4in lift question?????
Old Nov 3, 2009 | 11:58 AM
elk4's Avatar
OK here we go i have a 83 Toyota pickup with stock steering i will later down the road get cross over steering but for now i got way to good of a deal for the 4in leef springs i am getting i am just wondering what kinda problems i am going to run into for examples shocks and the stock steering will it work thanks for looking
Old Nov 3, 2009 | 03:01 PM
dropzone's Avatar
Fossilized
the stock steering will work for now, the only exception is that you might need a dropped draglink. WHen I first got my '81 it had a 4" lift with the stock steering. The draglink was stock, it sucked, swapped out to the dropped draglink--adjustable and that helped.
got rid of the stock push pull and went to High steer with a 94 IFS steering box...box better steering.
SHocks--probably gonna ride rough...
Old Nov 3, 2009 | 03:03 PM
camo31_10.50's Avatar
well..i believe you'll wanna get some new shocks...cuz your stock shocks aint gonna be long enough???
Old Nov 4, 2009 | 08:04 AM
elk4's Avatar
thanks for the info all i have to give him is my bumper for the springs so i think its a good deal and yes thay are toyota springs
Old Nov 4, 2009 | 12:31 PM
suncomb1's Avatar
You will need the dropped drag link, a dropped torque arm, an extension bracket for the rear brake proportioning valve lever, possible extended front drive shaft due to spline engagement, longer front / rear shocks, heavier front sway bar, maybe a rear sway bar and wider tires / wheels for stability.
Old Nov 4, 2009 | 02:47 PM
oldschool4runner's Avatar
I run 5" springs with the drop drag link, and it works well enough. I don't run any extreme trails, just street and dirt trails. I didn't have to extend the drive shaft but I retained the sway bar and that really limits my axle drop. If you don't use the torque bar and the sway bar you can gain a lot of wheel travel, but the on road handling is sacrificed.
If I had it to do over again I would have saved the $100 on the drop link and put it towards the crossover steering. That’s the next thing I plan on doing once I get back home.
Don't forget to post before and after pictures.
82yodahickman
34
May 16, 2017 01:00 PM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
