Pre 84 Trucks 1st gen pickups
front 3rd help
Old Jul 23, 2009 | 03:30 PM
ajoebob's Avatar
Exclamation front 3rd help
i was working on my truck getting it ready for a big ride this weekend and found out something in my frontend is trash. i have around 1/4" play in the drive shaft in and out and around. i i think i killed the 3rd. i have anuther one but i never pulled the front axles before. is there a fast way to do it?
i need to get it fixed tonight so i can go tomarow.
thanks
Old Jul 23, 2009 | 03:44 PM
slacker's Avatar
there should be NO movement in and out ...
I'd say it's toast .. best replace it .
other then not cleaning and repacking .. there is NO "fast way" to do it ..
Old Jul 23, 2009 | 04:27 PM
Scooby098's Avatar
Sounds like what my rear end in my truck was doing. I think it was the bearing that went out. easyer to just find a used one and roll it under.
Old Jul 23, 2009 | 05:20 PM
ajoebob's Avatar
if i had a new one i would but i dont and there hard to find around here.i will pull an allnighter and rebuild the thing.
Old Jul 23, 2009 | 06:09 PM
Plumbrbob's Avatar
ok so let me get this right
your 3rd it thrashed
you have a spare
you want to know is there a fast way to get the SFA inner axles out?
YES!
remove caliper
remove the steering arms upper and lower steering pin
remove the rock rings
rotate entire rotor and hub assmebly until the flat spots on the birfield are at 12 and 6 o'clock, shining a light down the trunnion bearing hole will help guide you to find this position.
Once the flat spots are stabbed rock the birf and inner axle out of the axle ball you will be taking the knuckle, rotor, hub assembly, birf and inner axle out in one shot
repeat on opposite side
of course the 3rd bolts and DS need to be removed
roll out bad 3rd
clean and rtv sealing surface
roll in new 3rd
lining up the flat spots on the birf at 12 and 6 o'clock rock the birf back in
note: check the trunnion bearing make sure they are lined up
reinstall rock ring
reinstall steering arms and pins and torque steering studs
Just so you know this can be a PITA if your axle ball is bent or your birfs are mushroomed
It can also be hard to do get the steering arms off and the cones if you can get yours off then ad some anti seize to the cones to make the next time easier
the rock rings seem tricky but plan an attack and its actually quite easy
HOPE THIS HELPS AND HOPE I DID NOT MISS ANYTHING
I'd help if you where in tacoma we woudl be done in a hour and a half
Old Jul 23, 2009 | 06:12 PM
Plumbrbob's Avatar
oh yea lock your hubs so you can rotate the inner axle LOL hope thats everything I'll keep thinking about it
Old Jul 23, 2009 | 07:57 PM
ajoebob's Avatar
thanks for the help i just got the 3rd out. it's not as bad as i thought. it looks like the crush sleve got crushed more, but its darkout so its hard to tell. i hit a rock perty hard and caved in my frount axle about 1/2" and then the pinion seal started leaking and now that i cheeked it i seen it was bad.
i'll have some new inter seals in the morning and i will put it all back together. it wasnt as hard as i thought it would be as long as it go back together as good.
Old Jul 23, 2009 | 08:28 PM
Plumbrbob's Avatar
sounds good
i stopped using crush sleeves beacause offroading is way to rough for em get a solid spacer keep that pinion gear from floating.
So did you take it apart the hub assembly or did you cheat and take the knuckle off?
Old Jul 24, 2009 | 11:02 AM
ajoebob's Avatar
i pulled the spindle off it wasnt to bad. when i regrear i'm going with solid spacers. evey thing looks good but the slop in the pinion.
Old Jul 24, 2009 | 02:15 PM
Plumbrbob's Avatar
thats the way I have to go these days since I have the 5th stud mod. but I dont get into my SFA too much these days. I have longfields, 5.29's, & a solid spacer
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
