Pre 84 Trucks 1st gen pickups
blinker problem
Old Dec 19, 2008 | 05:14 AM
foxracing31702's Avatar
blinker problem
my blinkers dont work, when i flip the switch up or down, they do nothing....when i flip the hazzard switch, they turn on and stay solid...would this be cause theres not a full circuit or maybe a flasher relay is bad?
Old Dec 19, 2008 | 06:27 AM
1styota4X4's Avatar
well first off you do not mention anything about checking the binker fluid...Check the FSM for instructions on how to its pretty tricky.
J/K on a serious note it sounds like the flasher is bad but start with the fuse and verify you have power there with a test light or multimeter.
Old Dec 19, 2008 | 06:31 AM
83's Avatar
83
Damn it I opened this thread just to suggest blinker fluid and you beat me to it!!
Old Dec 19, 2008 | 12:46 PM
1styota4X4's Avatar
did you have power at the fuse? Also did you replace the flasher?
Old Dec 19, 2008 | 04:56 PM
they have power....when i first started playing with the blinkers they would make that clicky noise a few times then stop....no when i turn my hazzard switch on, that little box down behind the glove box clicks ones then my blinkers just light up solid....maybe that little box is bad?
Old Dec 19, 2008 | 05:22 PM
slacker's Avatar
you need to check / replace your bulbs/sockets ..
check the sockets for rust .. that will impeed voltage .
Old Dec 19, 2008 | 08:41 PM
theyre all brand new lights
Old Dec 22, 2008 | 09:14 AM
red neckerson's Avatar
if you put led light in place of the regular lights it will not work for whatever reason, but i had to use the original lights which i zip tied in the engine compartment and run wires off them to my led's
SubiKing
Aug 21, 2021 03:57 AM
ghostmoney
Jan 28, 2018 11:42 AM
theking11863
Mar 19, 2016 09:36 PM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
