Pre 84 Trucks 1st gen pickups
need heat
Old Dec 21, 2008 | 08:27 PM
bruzryoda's Avatar
need heat
im just curious if anyone has a problem with first gen. pick up heater. my 81
4x4s heater is not warm at all. just got my new floor boards in, so now i dont
have that draft up the leg. but the thing just does not get warm. thinkig bout a hotter therm. but not sure.... has a new rad. and i made sure it was burpt so i would not have this issue. but same result as the old rad. any ideas would be sweet!!!
Old Dec 21, 2008 | 08:32 PM
scuba's Avatar
make sure the little wire on the pass. side is hooke up to the valve control, my heater wasnt working, looked at the pass side floor board by the middle dash and hooked the little wire up..WALA, HEAT !!
maybe a little too much since Im over heating...
Old Dec 21, 2008 | 08:35 PM
bruzryoda's Avatar
i have heat, but but it does not get very warm in the cab. guess i should have said that earlier...
Old Dec 21, 2008 | 08:38 PM
4runnermt's Avatar
Did you flush your heater core? It might be plugged up. I just flushed a core on a '01 z71 truck, and it made a world of difference.
Old Dec 21, 2008 | 08:44 PM
scuba's Avatar
Yeah, If you have heat just very little while it is "blasting"... Sounds like your heater core is plugged...
Old Dec 21, 2008 | 08:47 PM
bruzryoda's Avatar
not to sure if thats the prob. my bro. inlaw was the previous owner, and that was the last thing he replaced b 4 i bought it. he said it was cold on him to. but he only had 2 drive a mile to work.
Old Dec 21, 2008 | 08:48 PM
bruzryoda's Avatar
im thinking that it is a first gen trait....
Old Dec 21, 2008 | 08:49 PM
4runnermt's Avatar
What rating degree wise is your thermostat, and what does it read when warmed up fully?
Old Dec 21, 2008 | 08:52 PM
bruzryoda's Avatar
not sure. but, needle stays in the middle all of the time at full warm up. air warms up hotter when i accelerate more...
Old Dec 21, 2008 | 08:55 PM
4runnermt's Avatar
It really sounds like a blocked/plugged heater core to me. I don't think its any inherent problem with the age of the rig. You could try to flush the core and see if any crap comes out of it. Use distilled water and compressed air. Its worth a try!
Old Dec 21, 2008 | 08:59 PM
bruzryoda's Avatar
yehhhh, these things suck to get to the core. at least on nissans. not to sure bout yotas.. guess it worth a try. give me something to do next weekend.
Old Dec 21, 2008 | 09:00 PM
Sked's Avatar
Open up the hood and grab the 2 hoses that go into the heater core. Should be just as hot as the main rad hoses. If there hot then open up the flow control manually all the way. Still no heat then your core is plug up with junk which is not hard to flush out.
Old Dec 21, 2008 | 09:01 PM
4runnermt's Avatar
Pull the hoses from the radiator and do it in the truck w/o removing the core. Use a funnel to add distilled water into one hose, and blow compressed air into the same hose. Then go the other way. You will likely need three or so gallons of distilled water. I hope this helps!
Old Dec 21, 2008 | 09:03 PM
bruzryoda's Avatar
well duh i new that. my mind was not all there. thanx man!! im a dumb ass...
Old Dec 27, 2008 | 11:53 AM
bruzryoda's Avatar
nope, it was not a clogged heater core. gonna, buy a new therm. alittle later.
Old Dec 28, 2008 | 06:25 AM
fyreandwater's Avatar
Put a piece of cardboard in front of your radiator that covers up about half the radiator. It's a good trick if it's cold all the time. Just remember to take it out when the weather warms up. Worked for me and my truck gets warm driving about 5 miles to work.
Davebarbier
Nov 3, 2015 03:28 PM
mreagen
Oct 5, 2015 04:27 PM
Obmi
Oct 4, 2015 11:30 AM
Matthew Perez
Sep 28, 2015 05:43 PM
87runner_
Sep 19, 2015 03:28 AM
