Pre 84 Trucks 1st gen pickups
Wont role
Old Dec 30, 2008 | 03:27 PM
coptop's Avatar
Wont role
Looking at a 82 p/up on ebay has 35s on it now Seller says it wont roll on solid ground in four wheel drive unless it loses traction do to previous owner changing only rear gears and used to run 33s on front and 35s on rear. Can that really be the only problem
Old Dec 30, 2008 | 03:31 PM
AP4CHE's Avatar
Sounds like mismatched gears but it could be other things too. Do the wheels turn at all or are they locked?
Old Dec 30, 2008 | 03:36 PM
coptop's Avatar
Seller says it will roll about a foot but will go if on sand or snow also says 4.88 gears in back but stock front axle
Old Dec 30, 2008 | 03:37 PM
BigBluePile's Avatar
Well, it could be...if he unlocks the hubs there shouldn't be any problems! Seriously, I'd look some where else. Who knows what other sillyness is involved with this truck!
904_runner's Avatar
well if its binding up it maybe
Old Dec 30, 2008 | 03:40 PM
I suppose if everything else is in order, then only having to regear ONE diff is cheaper...
Old Dec 30, 2008 | 03:42 PM
904_runner's Avatar
well you never know peoples motives. I only regeared my rear diff, but thats because im getting ready to sas mine and dont feel the need to waste moeny on regearign the ifs for the short amount of time i will be running it.
Old Dec 30, 2008 | 04:06 PM
Right, and that makes perfect sense!!! Why regear a 7.5" diff that you can't reuse on a SAC?
Then again, why would you run 35's on the rear and 33's on the front?
Old Dec 31, 2008 | 06:31 AM
83's Avatar
83
If you check the truck over real close I'd say it might not be bad, but usually if the PO did mickey mouse work on one part of truck, they did it other places too. If you know your stuff about what to look for, and feel good about it after really looking it over & driving it, then it should be alright. It definitely raises some red flags, is all.
Old Dec 31, 2008 | 06:55 AM
dropzone's Avatar
Fossilized
1982 Truck on Ebay
that truck has been relisted at least once. Cosmetically the truck doesn't look bad.
Mismatched gears would definitely account for the issue he stated. The reason to run 35's in the rear and re-gear and run 33's up front with 'stock' gear, who knows. If you buy it make sure you pull the rear third and count the teeth before you buy a 4.88 gear set/third for upfront. That thing might have 5.29's or who knows what gears in the rear.
Old Dec 31, 2008 | 08:19 AM
83's Avatar
83
I could use that shell..
Old Dec 31, 2008 | 08:24 AM
yotaboy82's Avatar
the frame on that truck has been repared before.....i can see it on the pic where it kinda is showing the rear part of the frame......i mean no big deal. it looks like a good repair job to
crammit442
7
Nov 29, 2017 12:30 PM
greyheadedguy
Aug 18, 2015 10:40 AM
Churnd
Jul 18, 2006 02:43 PM
