Pre 84 Trucks 1st gen pickups
Chassis lube spots.
Old Dec 30, 2008 | 02:43 PM
95yoda's Avatar
Chassis lube spots.
Hi all,
I bought a small hand held grease gun that holds the smaller 3 oz tubes of grease, I decided I wanted to lube the zerks.
I found the one on the joint from the driveshaft to the transfer case and also found the 2 on the joint from the transfer case to the shaft going into the front diff, and the 4th one I found was the one on the joint going into the front diff.
so found 4 total, 3 took about 6 or 7 pumps of grease before coming out the zerk the 4th came out right away? maybe clogged???
anyway, where else can I find zerks to lube on my 82 4x4?
thanks guys.
p.s. I also bought a arosol can of grease and sprayed moving parts, figured it cant hurt, right? like the bottom and top of shock mounts, the shackles of the leafsprings and a few things up front. also the doors.
Old Dec 31, 2008 | 06:34 AM
83's Avatar
83
Do you have a service manual? It shows all the spots, and I'm sure you could fine one online. My truck has the little sun visor insert that shows all the spots to lube. There are steering components on the front that need lubing, maybe somebody with a diagram will post it, but a Factory Service Manual or even a Haynes or Chilton will likely outline all the places to grease.
Old Dec 31, 2008 | 08:18 AM
95yoda's Avatar
the haynes kinda does but it sucks. not detailed, I will look around the front area. how often to lube the zerks?
Old Dec 31, 2008 | 04:42 PM
slacker's Avatar
that sunvisor card is "on line " somewhere ... i did a quick search for ya bud .. but no luck .
maybe someone will post er' up !
Redeth005
Jun 28, 2018 08:16 PM
dbd6604
Oct 11, 2015 05:30 PM
TransAmBandit
Sep 20, 2015 06:08 PM
kelly1450
Sep 2, 2015 12:29 PM
Ryall
Sep 2, 2015 06:48 AM
