Pre 84 Trucks 1st gen pickups
83 4x4 manual hub need help!
Old Feb 16, 2009 | 12:44 PM
83 stump jumper's Avatar
Ok I have an 1983 Toyota 4x4 and I replaced my wheel bearings in the front, but me and my dad need the size of the nut that is in the hub so we can correctly tighten it. I called and asked for the size at Napa and they nicely told me that I am an idiot and that not what that sockets for. Then I looked on the internet and found a post on here saying that it was 54mm or 2 1/8. I also called the local Toyota dealer and they went and measured the socket they use in the shop and said it was 56mm. so i don't know what one is right and figured that someone on here has used that socket and knows the size. Sorry for such a long message and thanks.
Old Feb 16, 2009 | 01:25 PM
DeathCougar's Avatar
54mm.
Brian at WabFab sells the socket
Old Feb 16, 2009 | 01:36 PM
91Toyota's Avatar
Its about $30 at Sears. Or you can drive to my house and use it for free
Old Feb 16, 2009 | 01:43 PM
ok thanks so much
Old Feb 16, 2009 | 01:57 PM
jessekosten's Avatar
If it is the same nut as IFS a 2 3/32 socket will work (P/N KD 2430 at NAPA)
Old Feb 16, 2009 | 07:05 PM
dropzone's Avatar
Fossilized
54MM works out to 2.13, pretty dang close to 2 & 1/8" (2.125)
Old Feb 17, 2009 | 06:24 PM
thanks guys bought one at sears for $27 craftsman will finish next weekend. i got another question that doesn't have to do with my hubs but when i drive down the road at about 2,000 rpms my truck makes a rattling key noise and before i could get it to do it when stopped. so we thought it might be my rear end so i replaced the third member but it still makes the noise so let me know if you have an idea. Thanks
Old Feb 17, 2009 | 09:09 PM
808yotaman's Avatar
check yer u-joints....
Old Feb 18, 2009 | 05:16 PM
Ok sounds good thank you
glowz825
Jan 25, 2022 09:28 AM
oldirtydirt
Feb 23, 2020 09:30 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
