Pre 84 Trucks 1st gen pickups
I need some help
Old Jan 22, 2009 | 05:29 PM
OLD BLUE's Avatar
I need some help
I have an 83 pickup stock and the front end saggs a little bit and i was wondering what size shackles i could put on it to make it sit level any help would be appriciated
Old Jan 22, 2009 | 05:43 PM
yotaboy82's Avatar
OEM springs...longer shackles on saggy springs bad(well i think anyways)
Old Jan 22, 2009 | 06:07 PM
OLD BLUE's Avatar
how much lift should the OEM springs have just to make the truck sit level
Old Jan 22, 2009 | 07:34 PM
foskco87's Avatar
Pictures would help alot. I could compare to how mine sits and mine is stock as well.
Old Jan 23, 2009 | 07:12 AM
83's Avatar
83
Yeah my trucks front springs are flat, and I hear that's pretty much how they came from the factory. If you're getting some reverse arc on the other hand...maybe time to either re-arc or replace.
Old Jan 23, 2009 | 07:44 AM
yota8083's Avatar
I agree with the guys above. If your factory springs are sagging(reverse arch) then putting longer shackles on will just lift the truck a little but will do nothing to help the springs shape. In this case it is best to get new springs. Also, pics of the truck would be good.
Thomas
Old Jan 23, 2009 | 08:00 AM
refried's Avatar
Longer shackles on the front is very dangerous and illegal in most states. It changes steering geometry and allows the axle to move side to side when braking or cornering.
Old Jan 23, 2009 | 12:07 PM
foskco87's Avatar
I think yota8083 is right. I think the front springs should appear flat not arced like the rear ones so dont let that fool you. How ever if they have negative arc then they are probably sagging a little bit. Go to toyotareference.com and look at some of the new 1st gen truck pictures and you'll see the front springs are flat. Soo nice to see those old pickups in mint condition. I basically just drool the whole time.
Old Jan 24, 2009 | 08:36 AM
OLD BLUE's Avatar
They do have a neg arc thanks for the help
Old Jan 24, 2009 | 09:03 AM
OLD BLUE's Avatar
Were would be the best place to get new front spring fairly cheap
Old Jan 24, 2009 | 09:09 AM
4Crawler's Avatar
OME spring (Old Man Emu not OEM Original Equipment Manufacture - i.e. stock) are set up for about 2" of lift:
http://www.arbusa.com/Products/Suspe...prings/34.aspx
Old Jan 24, 2009 | 02:08 PM
foskco87's Avatar
Theres tons of auto part websites that sell direct replacement stuff. I cant really think of any off the top of my head but im sure someone else will be able to name a few. I think car-part.com is one.
Old Feb 4, 2009 | 06:18 PM
OLD BLUE's Avatar
Sweet thanks alot
