Pre 84 Trucks 1st gen pickups
cigarette ligher + power
Old Mar 5, 2009 | 01:27 PM
red1983's Avatar
Do your trucks work with cigaretter lighter plug in assories? I would like to use an ipod tuner in my truck and last time I checked, my cigarette lighter didn't seem to power the device... but the lighter itself works (last I checked). Was that device I tryed bad, is there something wierd with our trucks, or something wierd with my wirering?
Old Mar 5, 2009 | 01:34 PM
83's Avatar
83
Mine just plain doesn't work, so I can't help. I'm planning on just buying a new one that'll fit that spot and probably wiring it right to the battery so it gets power even when the truck's off. Maybe put a fuseable link in there somewhere...
Maybe it's just weak? Weak connection or something so it's enough to heat the lighter but not power something that takes more juice? I need to get an ipod setup in mine, too.
Old Mar 5, 2009 | 01:37 PM
4Crawler's Avatar
My '85 lighter works fine with 12 volt adapters. Might see if yours is dirty or oxidized inside. Also, check the fusible link behind the socket if there is no power. Mine melted on me after running a 12 volt cooler for a while. Only 4 amps draw but it was the on-time that took out the link. I re-powered my socket to a constant 12 volt wire to the battery so it is live all the time.
Old Mar 5, 2009 | 01:48 PM
mudhoney's Avatar
haha reminds me of working to get 12volts outta a 6volt on old bugs..at least you havnt got that step to traverse..gl
flashkl's Avatar
Mine had really questionable wiring at the back of the 12v plug so I went to radio shack and bought a new socket for 7 bucks and put it in. With the one I got, I just had to trim the plastic surround and then it fit perfectly, looks factory.
Old Mar 5, 2009 | 01:57 PM
83's Avatar
83
I think your write-up on that is what made me think of it, 4Crawler.
Old Mar 5, 2009 | 02:07 PM
snobdds's Avatar
I have the same problem, my lighter works but my Zune turner doesn't. I was going to try and clean the contacts and see if that works. Other than that, it's just plain weird that the lighter works but others things do not.
Old Mar 5, 2009 | 02:10 PM
83's Avatar
83
The force must be weak with it
Old Mar 5, 2009 | 02:45 PM
snobdds's Avatar
The force is weak on a lot of things right now...except patience
Old Mar 5, 2009 | 03:09 PM
red1983's Avatar
I agree...
I will check out cleaning it + the fusible links.
Old Mar 5, 2009 | 03:24 PM
TacoNut's Avatar
Just a thought, but some adapters have an adjustable tip that screws in and out so it will fit the socket properly. Don't know if this is true of yours.
Old Mar 5, 2009 | 03:47 PM
littlecommando's Avatar
check the conections, i think there are 2
Old Mar 6, 2009 | 12:23 AM
peckm888's Avatar
the back connector that connected to the very middle of mine was loose and messed up sometimes on my ipod thing. i made it tighter my squeezing it a little then connecting it agoin. my guess is your connection is bad. check all the wires
Old Mar 6, 2009 | 11:04 AM
surf4runner's Avatar
do you have another to try it in?
mine works fine.
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
TDonkey
Jul 26, 2015 10:14 AM
