Pre 84 Trucks 1st gen pickups
20r and 22r same timing chain ?
Old Jan 29, 2009 | 08:52 PM
ktown808's Avatar
simple question do the 20r and the 22r use the same timing chain been lookin on ebay for just a replacement kit but they only have for the 20r and for the 22r with single timing chain my 22r is a 82' so dual row thanks, aloha
Old Jan 29, 2009 | 09:04 PM
beat86's Avatar
My motor is an 82 and i just did this. As far as i know they are the same on these years but dont quote me im not 100%
I can find out tomarrow for sure
Old Jan 29, 2009 | 10:00 PM
scuba's Avatar
DUAL ROW TIMING CHAIN
Old Jan 30, 2009 | 06:10 AM
slacker's Avatar
yes they are ...
20r chain will fit up to /84 . they even have steel back guides .
for those of you with a single chain , whom might want to convert , all you will need to replace are the guide bolts , and the oil pump gear .
one of the engines I built , /84 EFI duel row chain
Old Jan 30, 2009 | 08:19 AM
83's Avatar
83
So you don't need the timing cover off a 20R? I thought engnbldr told me I did, but that would really help if I didn't. I seem to remember that some 22R's were double row, so that would make sense.
Old Jan 30, 2009 | 04:02 PM
slacker's Avatar
it's the same cover !!!
the ONLY differance between covers from 79-84 are the water pumps .. the later has 1 more bolt holding it down .
Old Jan 30, 2009 | 06:06 PM
ktown808's Avatar
right on thanks guys
Old Jan 30, 2009 | 07:37 PM
kdo58's Avatar
22r and 20r timing covers are not the same. a 22r has heater by pass connection on the back of the cover on both sides, a 20r only has it on the passenger side, a 22r has en extra hole under the oil pump. I know because i found out the hard way.
Old Jan 30, 2009 | 08:51 PM
slacker's Avatar
ahhh , yeah .. you are correct ..
but they are the same size .. meaning a 20r dbbl chain will fit under a 22r cover , and vise virsa .
Old Feb 2, 2009 | 06:12 AM
83's Avatar
83
Great
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
87blyota
Jul 10, 2015 04:31 AM
